ᐅ Stringer partially in front of window – should the stringer be notched out?
Created on: 25 Oct 2019 10:51
chrisw81
Dear forum members,
We have just received the plans for our U-shaped staircase.
As we feared, part of it will run in front of the hallway window.
One idea from the staircase builder is to cut out the stringer in the visible window area and add an extra tread that extends in front of the window.
It looks good on the drawing at first, but I’m not sure if it will look good in real life with such an irregular stringer...
Certainly, the window could make it look nice again, but I’m still uncertain...
Attached are photos of the plan...
Thank you for your opinions!
Technical drawing of a staircase on a sloped wall with steps 6–10 and surrounding landing.
Interior view: wooden steps, white railing, green walls, window in the background.
Interior stairway: green walls, brown wooden steps, white railing, red window frame.
Schematic drawing of a sloped ramp with stair steps and a rectangular interior area.
Tego12
26 Oct 2019 17:20
Letting it run through is the lesser evil; I would do the same.
11ant27 Oct 2019 02:58
chrisw81 schrieb:
This is not about uncertainty
I meant: the things you still show up with right before the final deadline are quite remarkable.
chrisw81
27 Oct 2019 08:32
What you manage to pull off right before the final deadline is pretty unique.
I wouldn’t have thought so either. It really shows the value of good planning and a skilled architect from the start. But you can’t think of everything or know everything during the initial planning phase. Some issues only come up during the course of the construction. You also get a lot of input from the tradespeople. It’s great that forums like this exist.
Mottenhausen
30 Oct 2019 14:10
Will a railing be installed in front of the window by the staircase?
If so, the window will hardly be visible, right?
chrisw81
1 Nov 2019 10:43
Mottenhausen schrieb:
Is there going to be a railing in front of the window on the staircase?
If so, hardly anything of the window would be visible, right?
No, there won’t be a railing in that spot. There is only a post on the inside at that location.
