ᐅ Ideas for Enhancing Building Facades
Created on: 11 Jun 2019 09:37
Kalusha
I’m new here and have a question right away.
I’ve added an extension. The original building is brick, and the new part is coated with plaster in RAL1015.
Somehow, I’m not really happy with how it looks. Does anyone have ideas on how to improve the appearance?
I’ve already thought about attaching brick slips, but the original brick is quite old (35 years).
Michael
Modern detached house with stainless steel chimney on the roof; garden with trampoline.
Modern beige detached house with dark roof, metal chimney, terrace, and trampoline in the garden.
Exterior view of a house with blue solar panels on the roof, round window, and garden path.
Kalusha
12 Jun 2019 06:48
Honestly? Your house doesn't seem completely unfamiliar to me; I think I might have seen it in the green forum last year?
No, definitely not.
Thank you all for your opinions and ideas.
Buchweizen
12 Jun 2019 09:16
I would also paint it white. Definitely not dark! Otherwise, you’ll end up with a shapeless block attached to an already not very inviting old building.
And a genuine improvement, even if probably unintended, would be the removal of the huge chimney pipe.
Tego12
12 Jun 2019 14:13
I don’t see the extension as the problem; the issue is more the unattractive brickwork, which looks very outdated... But there’s probably not much that can be done about that.
11ant12 Jun 2019 19:36
I appreciate that the house honestly acknowledges its extension, meaning the addition is integrated harmoniously but not assimilated.
Buchweizen schrieb:
And a genuine improvement, although probably unintended, would be the removal of the huge chimney pipe..
This was one of the details that seemed familiar to me – however, I would find it more attractive to give it a capped off extension down to the ground.
12 Jun 2019 22:11
guckuck2 schrieb:
The Waigel eyebrow dormers (slate) above are also quite unique.
Buchweizen schrieb:
it would be the removal of the huge chimney pipe...
Tego12 schrieb:
more so the rather unattractive brickwork that looks very outdated...
Wow, that really seems like an attack on the original building. How does one even come up with that idea?!
I just noticed the covered porch/conservatory. I would paint it white... or light gray.
Maybe it could also serve as a link between old and new. For example, you could paint the facade on that side with wood in the same color as the porch. If you have a soft spot for Falu red or Greek blue...!
cschiko
13 Jun 2019 07:19
I would also lean more towards white or a lighter gray shade and maybe incorporate that somewhat into the existing structure. Right now, the colors only match to a limited extent. Of course, a wood cladding or another type of cladding could work well, but then you would definitely run into issues with the window.
The brown of the windows could theoretically be a unifying element, but painting the extension brown? I don’t think that would be ideal either.
