ᐅ Sound Insulation – Noise from the Bedroom
Created on: 13 Jan 2019 07:46
Mummy
Mummy
13 Jan 2019 07:46
We have a solid concrete block house made of aerated concrete (Ytong) and chose a wall thickness of 36cm (14 inches) between our bedroom and the children’s room instead of the originally planned 16cm (6 inches). Unfortunately, since our TV is placed directly against the wall to the children’s room, almost every word from the TV can be heard on the other side. We’re now hesitant to do anything else like watching TV in the bedroom to avoid disturbing the little ones.
What options for additional insulation between the rooms make sense here? So sticking egg cartons to the wall is out of the question. We have considered whether it would be sensible to install a drywall partition in front of the existing wall and insulate it with mineral wool to achieve the desired effect.
It might also be important to know that the entire floor on this level is installed continuously without gaps at the thresholds, and the ceiling above consists only of drywall, a vapor barrier foil, and a layer of insulation wool, with the open attic directly above that. Therefore, I’m not entirely sure whether the noise transfers mostly through the wall, over the floor, or through the ceiling and where the best place to start would be.
What do you think?
Thank you very much,
Martin
HilfeHilfe
13 Jan 2019 09:54
TV in the living room and not in the bedroom
tomtom7913 Jan 2019 10:09
It’s not just about the TV.
HilfeHilfe
13 Jan 2019 14:06
At 49, he just watches TV ...
Mycraft13 Jan 2019 14:12
Partition wall with soundproof drywall including sound-insulating filling material is definitely a good choice. SK1 (or better) doors with matching frames and drop-down seals on both sides.
Mummy
13 Jan 2019 16:03
HilfeHilfe schrieb:
At 49, just watches TV ...
Well, what’s left when the children are watching "live" :-/
