ᐅ LED spotlights above the shower – waterproofing?
Created on: 5 Jan 2019 23:58
sco0ter
sco0ter
5 Jan 2019 23:58
we will have LED spotlights installed in the bathroom, especially above the shower. The electrician will be fitting them soon.
Our painter was concerned that too much moisture might rise above and mentioned that there are special waterproofing measures or “sealed” spotlights. He wasn’t sure about the details.
By “above” I mean: drywall panels where the spotlights will be installed, then a small cavity with battens, and then a vapor barrier.
Is there anything specific we should pay attention to? Are there such special waterproofing products? I’m not confident that our electricians will consider this much, other than maybe installing waterproof spotlights.
Nordlys
6 Jan 2019 09:26
We have that too. LED spotlight above the shower. The ceiling was plastered, painted twice with latex paint, and the spotlight over the shower was sealed with a bit of acrylic. It provides light sealing since it’s not constantly exposed to water there, but it doesn’t stick so strongly that you couldn’t remove the spotlight again if needed. Is this up to professional standards? Don’t know. But it works. Karsten
nordanney
6 Jan 2019 10:17
I wouldn’t do anything at all. Just install recessed lights that are suitable for damp rooms, and that’s fine. It’s just increased humidity.
Lumpi_LE
6 Jan 2019 10:18
Yes, moisture-resistant recessed lights are fine, as they have a seal.
sco0ter
7 Jan 2019 17:38
The concerns raised were that moisture would "rise" between the drywall and the vapor barrier, accumulate there, and basically damage the drywall ceiling from above.
However, I believe these concerns are somewhat exaggerated.
7 Jan 2019 23:05
sco0ter schrieb:
But I think the concerns are a bit exaggerated
When I see how damp our ceiling is after a shower, I don’t think it’s an exaggeration.
The difference might also be due to the partition and its length, allowing the condensation to spread out more or collect at the top.
