Macassian12 Sep 2021 08:47Hello everyone,
I’m wondering: why don’t replacement parts for Malm always fit together properly? Recently, I tried to assemble a Malm shelf and noticed that some pre-drilled holes didn’t line up exactly, and screws didn’t fit correctly. I understand that there can be different production batches, but is that really the main reason? Could the issue be related more to manufacturing tolerances, material warping, or even design changes that aren’t clearly documented?
I’m especially interested if anyone has detailed insights into IKEA’s manufacturing processes or has personal experience with replacement parts that had to be exchanged even though they were supposedly meant for the same piece of furniture. Thanks for your input!
RonJarrett12 Sep 2021 10:03Discrepancies with Malm replacement parts often result from several factors. Firstly, manufacturing tolerances for budget-friendly furniture are usually more generous to reduce costs. Secondly, different suppliers may be involved, which can cause variations in material thickness and drilling positions even for identical components.
Additionally, design changes made during the production period without a thorough update of the replacement parts logistics can lead to parts from different generations not fitting together precisely. Unfortunately, IKEA rarely provides public details about such processes, so customers are not always fully informed.
Rashadmeo12 Sep 2021 10:41Wow, that sounds really complicated! 🙂 But it’s great that you know so much about the details! I’ve often noticed with IKEA furniture that it’s practical, but doesn’t always fit perfectly, especially when you take it apart and put it back together. Still, I think it’s great that replacement parts are even available, even if they don’t always fit exactly! That shows IKEA’s effort to become more sustainable and not just push for new sales. So keep your chin up, it’s not the end of the world! 🙂
RonJarrett schrieb:
Design changes made during the production phase without thorough updates to spare parts logistics result in spare parts from different generations not fitting together precisely.That is an interesting hypothesis. However, a global company like IKEA should maintain proper version control and documentation to prevent such issues. I suspect this is more likely due to insufficient quality control and possibly cost-cutting measures. Are there reliable sources documenting the different production versions? Otherwise, much remains speculative.
To add some technical detail: Environmental factors such as moisture absorption and the expansion or shrinkage of solid wood components significantly affect their fit. This explains why small parts in some older or replacement components do not always fit well together.
Material distortion is therefore a real factor. Additionally, manufacturing tolerances of +/- 1 to 2 millimeters (0.04 to 0.08 inches) cause inaccuracies when replacing individual components. IKEA also uses different material batches and production facilities, which further complicates the compatibility of spare parts.
Taken together, this makes it understandable why not all Malm replacement parts are perfectly coordinated.
