ᐅ Why does the MALM bed squeak despite proper assembly?
Created on: 28 Nov 2021 21:07
Klari
Klari
28 Nov 2021 21:07
I recently assembled a Malm bed, and although I followed the assembly instructions carefully and tightened all the screws properly, the bed still squeaks with every movement. The noise occurs mainly when I turn over or sit up, which is really annoying. Does anyone have an idea why this might be happening despite careful assembly? Are there any materials that could help reduce the squeaking afterwards, or mechanical issues that can be fixed by oneself? I would appreciate any tips!
naujon
28 Nov 2021 21:45
The issue "Why does the MALM bed squeak despite correct assembly?" is actually quite common, even when the instructions have been properly followed.
First, it is important to identify the exact source of the squeaking. Typically, the causes are:
1. Connections between wood and metal or wood and wood – slight movement can occur here, causing squeaking due to friction.
2. Incomplete tightening of screws or small gaps that become noticeable under load.
3. Bearing points or bolts without lubrication or protection against wear.
Tips for solving the problem:
- Double-check all screws and nut connections with a torque wrench (if available). Often, you can feel a difference when tightening by hand.
- Place thin felt or rubber pads between connection points – this helps dampen friction noise.
- Apply special furniture oils or silicone spray (sparingly!) to edges or connection points to reduce friction.
In summary: Even if the assembly was done correctly, small material or tolerance variations are normal. Usually, simple damping measures and targeted retightening provide a solution.
tolokau
29 Nov 2021 06:19
naujon schrieb:
The problem "Why does the MALM bed squeak despite proper assembly?" is actually quite common
I completely agree! I had the same issue and discovered that especially the connection between the slatted frame and the bed frame often squeaks because it’s not completely tight.
Practical solution:
- Once all the screws are fully tightened, I lightly apply wax or candle wax to the contact surfaces – this can help reduce friction.
- By gently roughening or carefully sanding the connecting surfaces (very carefully!), you can sometimes achieve a better surface texture that squeaks less.
An important point is that the wood slightly expands and contracts due to changes in humidity. This creates tiny gaps that become noticeable under the weight.
Conclusion: Squeaking despite proper assembly is usually a combination of mechanical tolerances and material properties. However, it can often be noticeably improved with simple household methods.
koduga
29 Nov 2021 09:33
I had the same problem myself, and I know how frustrating it is to have a new bed that squeaks despite all the effort during assembly.
Klari schrieb:
The noise mainly occurs when I turn over or sit up
In my case, it was because the support points of the slatted frame didn’t sit exactly on the metal rails, causing movement under load.
What helped me:
- Attach felt pads where the wood meets the metal.
- Periodically check and tighten all screws.
If you like, I can also recommend completely disassembling the bed and doing a quick test beforehand to identify any joints with slight play.
The noise is annoying, but usually solvable with patience! I’m keeping my fingers crossed that it works out for you too.
Ixfu2
29 Nov 2021 12:02
Squeaking despite proper installation often comes from:
- loose screws
- lack of lubrication on contact points
- moving parts that rub against each other.
Tips:
1. Retighten screws properly
2. Treat contact points with furniture wax, candle wax, or silicone spray
3. Use felt pads if wood rubs against metal
This is usually enough; nothing more is needed.
