I have a somewhat specific question that I’m sure some of you have encountered before: Why is it sometimes difficult to assemble the IKEA Brimnes wardrobe or furniture piece, meaning the individual parts don’t fit together smoothly or easily, even though everything is positioned correctly according to the instructions?
I get the impression that there could be several reasons, such as minor dimensional inaccuracies of the wooden parts, uneven pressure when joining pieces, or perhaps different material temperatures. However, I also wonder whether the connection points like dowels, screws, and tongue-and-groove joints in this model are generally not perfectly matched—or if these are just occasional issues related to manufacturing.
I’m interested to know if any of you have experience with the Brimnes and maybe have some tips or practical advice on how to make the assembly go more smoothly. Or do you think it comes down to design or production tolerances?
Looking forward to your opinions and suggestions.
GUSTAVO56 schrieb:
I’m also wondering: How do you store the components? If the materials are kept for a long time in a place that’s too humid or too dry, they can easily warp.That’s a good question. I kept the parts in their original packaging, and when assembling, the apartment was at a normal temperature and neither particularly humid nor dry.
What I also noticed is that although the instructions are fairly clear, sometimes detailed close-up images of the joints are missing. This could actually cause someone to insert, for example, the dowels slightly off-angle and then create pressure.
So thanks to everyone for the tips. Before my next attempt, I will definitely check the edges and possibly sand them lightly.
And yes, Karsten45, I also pressed too hard at times—I want to finish quickly, but in the end, that just causes frustration.
I’m also curious: Has anyone ever ordered replacement parts for Brimnes if a hole or groove didn’t fit? How straightforward was that?
LEARNE schrieb:
I’m also curious: Has anyone here ever ordered replacement parts for BRIMNES in case a hole or groove doesn’t fit? How straightforward was that?I also had a somewhat stressful assembly experience with BRIMNES about a year ago. I actually ordered replacement parts through IKEA, and their customer service was surprisingly quick and friendly.
It’s always important to provide the exact article number and clearly identify the defective part, preferably with photos (if allowed). The delivery was free of charge and arrived within a few days. What I recommend is not to wait too long to order replacements if something doesn’t fit – the sooner you have the parts, the less stressful it will be.
I completely understand that assembly can be frustrating when the parts aren’t perfect. We’ve all had moments like that with IKEA at some point. 😊
Maybe a tip for LEARNE: If you experience serious fitting issues, you can also ask in the local IKEA store – they often have additional advice or can initiate replacement parts directly.
I would like to support the points made by GUSTAVO56 and fugolo and add a small technical tip.
When parts fit together too tightly, it is often due to dowels or connecting pieces being inserted at an angle. A simple but sometimes very helpful method is to slightly sand or file the ends of the dowels to make them just a bit slimmer. This eases the fit.
However, excessive material removal should be avoided, as it can compromise the stability.
I also recommend not tightening the screws right away, but first assembling all parts loosely and only fully tightening them at the end. This seems especially useful for the BRIMNES, with its many connections, to prevent stress or distortion.
Using a rubber mallet to gently tap the joints into place is a classic technique, if necessary. But please be careful not to cause any damage.
Finally, patience and taking short breaks can also be extremely valuable when working with such furniture.
