ᐅ Why is the Billy bookshelf still wobbly despite wall anchoring?
Created on: 16 Feb 2021 08:17
pipeke
I have anchored a Billy bookcase combination to the wall, but the furniture still wobbles noticeably, especially when you shake it or place something inside. The plugs and screws are firmly installed, the wall is solid (concrete), and I followed the assembly instructions precisely. Still, it wobbles.
Can someone explain why this might be? Is it related to the design of the Billy shelving unit itself, or are there specific aspects of wall mounting that should be considered? I would like to understand what is causing the issue so I can find a solution if needed.
Thanks for your advice!
barEsperan
16 Feb 2021 10:37
Missing leveling pads under the floor often cause problems as well. Did you place them under the shelves for stabilization? They compensate for minor unevenness and reduce wobbling.
plopra
16 Feb 2021 11:05
Does the shelf possibly have contact with the floor? Wobbling often occurs when the floor is uneven and the shelf does not rest fully on it.
pipeke
16 Feb 2021 11:28
dunitan schrieb:
The wobbling might also be caused by the screws and wall plugs being tight, but the actual connection not being completely flush.
That could indeed be a factor. I followed the assembly instructions strictly, but perhaps the screws are slightly misaligned despite being firmly anchored.
Luciandi schrieb:
that the anchoring on the wall is at the height of the upper shelves
I secured the fixture in the middle of the back panel. Maybe that’s too low and creates more leverage if there is weight on top?
The idea of adding extra screws for the back panel sounds interesting. So far, I have only used the small nails. Could that really improve stability noticeably?
TARAON
16 Feb 2021 11:50
pipeke schrieb:
I installed the bracket in the middle of the back panel. Maybe that’s too low and causes more leverage
Exactly! 🙂
If the bracket is too low and there’s weight on top, the shelf basically thinks, ‘Hey, I’m going to tip over!’ A bit of leverage effect due to the distance from the hanging point.
So: Attach the bracket as close as possible to the top edge for the most stable leverage arm. Logitech once said: “The shorter the lever, the more power against wobbling.” 😉
Tightening the back panel firmly works wonders. A few screws or stronger nails make a big difference, trust me.
kenkeo
16 Feb 2021 12:38
Super interesting here, everyone! My experience also confirms that if the anchoring is too deep, it can cause wobbling.
What can also help: temporarily place a layer of wooden shims in the gap under the shelf until the anchoring is optimized. This way, the Billy won’t start to sway while you are testing different screw positions.
I recently did this for a friend and was impressed by how stable it stood afterward! Just give it a try.
Luciandi
16 Feb 2021 14:12
Just to revisit the back panel: it is often underestimated, but it actually provides most of the stability.
TARAON schrieb:
And tightening the back panel works wonders. A few screws or stronger nails really make a difference
Sometimes a poorly fitted back panel can make the entire shelf shaky, especially if it’s not completely flat and tight.
If you’re unsure about making adjustments, I understand, but it is definitely worth doing carefully. 🙂
