ᐅ Why does BILLY warp with temperature changes?
Created on: 23 Dec 2020 14:37
Fogoge
Fogoge
23 Dec 2020 14:37
Hello everyone, I have recently noticed that my IKEA BILLY bookshelf warps slightly during more significant temperature fluctuations. This mainly affects the shelves and sometimes the back panel. I am curious as to why BILLY bookshelves show these deformations when room temperature changes. Are the materials particularly sensitive due to their composition? What are the specific mechanical and physical reasons that cause the furniture to warp? I would appreciate it if someone with a technical background or experience could provide a detailed explanation.
renpeo
23 Dec 2020 15:03
Hello Fogoge, your question is very well and precisely formulated. BILLY shelves are mainly made from wood-based panels, which consist of compressed wood fibers and synthetic resins. These panels react to moisture and temperature because wood can swell or shrink, leading to distortions.
Temperature changes usually also cause variations in relative humidity, and wood panels are very sensitive to this. This results in stresses within the material, which manifest as warping.
In short: it is the interaction of the material properties (wood-based panel, moisture absorption) and the related swelling or shrinking that causes your shelf to warp with temperature fluctuations. If you like, I can explain this in more technical detail.
kibutar
23 Dec 2020 16:19
I would like to provide a more detailed answer to Fogoge’s question, as the behavior of materials under temperature fluctuations is quite complex.
BILLY shelves are made from particleboard panels with a melamine resin coating. Unlike solid wood, these engineered wood panels have a somewhat more uniform structure, but they are still sensitive to changes in moisture and temperature.
Basically, engineered wood deforms due to the different swelling and shrinking behavior along the different axes (parallel to the grain, perpendicular to the grain). Although particleboard is more homogeneous than solid wood, moisture absorption still causes anisotropic (direction-dependent) expansion.
Temperature changes alone also cause expansion or contraction; however, this factor is usually less significant in furniture construction than moisture.
Deformation occurs when components are exposed unevenly to moisture or temperature, for example, if one side is closer to a heater or there is uneven air circulation. This creates internal stresses within the panel, which can result in bending, warping, or bowing.
In practical terms:
- Dry heating periods in winter can dry out engineered wood and cause it to shrink.
- Humid air in summer causes it to swell.
- Temperature fluctuations further amplify these processes through material expansion or contraction.
If your BILLY shelf is placed against a wall that is poorly insulated or unevenly heated, this accelerates the effect.
If more specific details are of interest, such as technical data on the coefficient of expansion for particleboard, I’d be happy to provide them.
Best regards!
ronti
23 Dec 2020 17:05
The cause is actually simple: wood-based materials swell when exposed to moisture and shrink when dry. Temperature fluctuations usually affect the humidity levels as well, which is why the shelf warps. It is not the wood itself, but the variation in humidity that is the main reason.
LOJOPAR
24 Dec 2020 09:41
Hello Fogoge,
I would like to summarize in a structured way why your BILLY shelf warps with temperature fluctuations:
1. Material structure: The shelf is made of particleboard, which consists of pressed wood chips bonded with adhesives. These panels are stable but sensitive to environmental conditions.
2. Moisture absorption: Since wood-based materials are hygroscopic, they absorb or release moisture from the air—even if the surface is coated, moisture can still penetrate.
3. Temperature-related relative humidity: When room temperature rises, relative humidity usually decreases, and when temperature drops, it increases. These fluctuations directly affect the wood-based material.
4. Uneven swelling: The panels, which vary in thickness and coating, swell differently, causing internal stresses.
5. Mechanical consequences: These stresses lead to warping, cupping, or bowing, often affecting thinner shelves or back panels.
6. Prevention: Maintaining a consistent room temperature with minimal relative humidity changes, ensuring good ventilation, and avoiding direct heat sources near the shelf can help minimize these issues.
Summary:
ronti schrieb:
Temperature fluctuations usually also change air humidity, which is why the shelf warps.
This causality hits the mark. Temperature changes indirectly cause volume changes in the wood-based material through variations in humidity.
I hope this helps you! If anyone has additional tips on maintenance or construction of cabinet furniture, please feel free to add.
