ᐅ Why do the shelves sometimes come loose in BILLY?
Created on: 3 Apr 2021 08:37
Fraus9
Fraus9
3 Apr 2021 08:37
Hello everyone, I have had a Billy bookshelf from IKEA at home for a while, and I have noticed that the shelves sometimes come loose or slip out of the support rails. My question is: Why do the shelves sometimes come loose with the BILLY, even though the design seems quite simple and sturdy? I have made sure to insert the shelves correctly and not to overload them, but I still can’t always get them to stay firmly in place. Could there be quality differences in the materials, or is it more related to the assembly method? Maybe the positioning in the room or the humidity level is a factor as well? I would appreciate some well-founded explanations and tips on how to prevent this problem permanently.
Lisele
3 Apr 2021 09:02
I can easily understand how frustrating it is when the shelves keep falling out. That has happened to me as well, and honestly, it can be disappointing because you expect the furniture to simply hold together. It could also be due to the small plastic brackets or pins that hold the shelves, which sometimes stretch out or break. I’ve tried to be careful when pressing them in, but if the material is already a bit brittle or changes due to temperature fluctuations, it loses its grip. Maybe we should also keep in mind that IKEA-type furniture is designed for easy assembly and doesn’t seem as sturdy as, for example, solid wood shelves. 🙂
gadalu
3 Apr 2021 10:15
The cause of shelving boards coming loose in BILLY units is usually related to the type of support used. BILLY shelves use hammered metal pins or plastic dowels as resting elements, which are inserted into pre-drilled holes in the shelf frame. These components support the load depending on weight and mechanical stress. If the holes in the shelf frame become worn or enlarged, the pins can no longer hold securely, causing the shelf board to come loose. Similarly, overloading can cause material stress leading to slight deformation. Environmental factors such as increased humidity can cause the wood-based panel material to swell, which also contributes to loosening. Recommendation: Regular inspection and, if necessary, replacement of the support elements with more robust, commonly available alternatives can improve durability.
Grace
3 Apr 2021 11:03
Hello, to revisit the mechanical basics: The shelves of the BILLY series are typically made of laminated wood-based panels and rest on small pins. These pins are simply placed into pre-drilled holes and are not screwed in, which means they can shift under heavier loads. Especially with frequent removal and reinsertion of the shelves, this movement can increase and may cause the shelves to come loose more easily. A useful tip is to always remove and replace the shelves carefully and check the pins to ensure they are still intact. Applying a small amount of clear adhesive to the pins can help if the shelves repeatedly come loose.
laureo
3 Apr 2021 13:27
Another technical consideration: The type of installation for the shelves themselves is important. BILLY bookcases are designed modularly, meaning the shelves simply rest on pins. These pins or dowels are not locked in place, which is fundamentally correct to allow flexible shelf positioning. While this design makes the bookcase simple and cost-effective, it compromises stability. The surfaces of the pins and the condition of the holes in the frame are key factors. If the drill holes or the hole walls are no longer clean, small gaps can develop that may cause the shelves to slip out. Additionally, installation errors such as uneven shelves or irregular load pressure can worsen the problem. A possible solution is to attach rubber buffers to the pins to improve grip.
Dwight49
3 Apr 2021 15:42
From a technical perspective, it is also important to mention that the BILLY shelves are neither glued nor fixed in place; the plastic or metal pins are simply inserted mechanically into holes. When shelves are frequently repositioned, the drilled holes in the load-bearing part of the shelf may become worn out. Additional stress or force can then cause the shelves to pop out later on. Another possible cause could be material fatigue, especially if the shelves are unevenly loaded. I recommend using the appropriate original parts and checking that they fit securely. Replacement parts are available from IKEA if anything is damaged.
