I’ve noticed that one of my Malm bedside tables from Ikea wobbles significantly more than the other. My question is: Why do some Malm bedside tables wobble more than others, even though they are supposed to be identical? I have already checked whether the floor is uneven or if the screws are loose, but that is not the case. It is especially important for me to understand whether there are design-related differences or other factors that could affect the wobbling. Does anyone have experience with Malm bedside tables or general tips on how to reliably fix this issue?
Basically, there are several reasons why identical Malm nightstands can wobble to different degrees.
1. Uneven floor: Even if the floor seems level, there can be slight unevenness that becomes more noticeable with some pieces of furniture.
2. Assembly errors: Slight variations in how tightly screws are fastened can affect stability. Furniture like the Malm series often relies on precise assembly to prevent wobbling.
3. Manufacturing tolerances: Even in industrial mass production, small deviations in drill holes, connectors, or particleboard thickness can make a difference.
4. Minor warping: Moisture and temperature changes can cause minimal warping of the wood material, which becomes noticeable during assembly.
My tip: To improve stability, self-adhesive felt pads or thin shims under individual table legs can help compensate for minor floor unevenness. Also, double-check all fasteners to ensure they are securely tightened.
draleo schrieb:
self-adhesive felt pads or thin underlays under individual table legs to compensate for any floor unevennessExactly! Sometimes it's the little things – a bit of felt here, a tiny wedge there, and the bedside table stands perfectly stable. 🌟
I’ve had similar experiences: the Malm series bedside tables are sturdy, but since they are designed to sit on a level floor, even small height differences become noticeable. One table wobbles, while another stays steady.
Another tip: sometimes adjustable furniture glides with screws help – you can customize them precisely to level out unevenness. It’s an easy solution that also looks neat. 🙂
To delve a bit deeper into the technical aspects:
The wobbling of Malm nightstands often results from a combination of factors working together. These nightstands are mainly made from particleboard with a melamine coating, which is cost-effective but susceptible to moisture fluctuations. If you place such a nightstand on cold tiles or in a room with high humidity (e.g., a bedroom with open windows during summer), the panels can slightly warp, causing minor misalignments at the joints.
Furthermore, the furniture design of flat-pack products relies on particleboard and dowels to provide sufficient stability, but these dowels are not as sturdy as solid wood joints. If the dowel holes were not precisely aligned during assembly, slight play can occur even when the screws are tightly fastened.
The contact surfaces between the individual components can also be a source of issues: a small unevenness where the side panels rest on the top panel can significantly affect overall stability. Therefore, it’s important to carefully inspect the connections and possibly adjust them with small support strips or felt pads.
Have you noticed if the nightstand wobbles more in certain positions within the room or under different loads? That could provide additional clues.
lorena schrieb:
Have you noticed that the bedside table wobbles more in certain room positions or under different loads?Good question! It might help to place the table on a different surface to determine whether the issue is with the floor or the furniture itself.
Otherwise, try tightening the screws again, adding felt pads underneath, and checking whether all connecting parts are properly secured. Usually, that’s the cause.
