I’m currently dealing with an issue I noticed with my BILLY shelves: Why do some connectors come loose relatively quickly, even though they seem to be properly and firmly installed?
Specifically, I mean the dowels and screws that connect the shelves or side panels. Often, after some time, you notice the shelf wobbling or losing stability – and on closer inspection, some of the connections are already loose or have completely come apart.
I’m curious whether this is due to the design, the assembly, or perhaps unnoticed material properties. Are there any known weak points or tips on how to ensure a more secure and lasting installation? I look forward to your experiences and suggestions!
Gojakin schrieb:
Why do some connecting pieces in BILLY shelves come loose relatively quickly, even though they seem to have been assembled correctly and tightly?A frequently overlooked factor is the material quality and load distribution in BILLY shelves. The connectors, especially the so-called Minifix fittings, are designed for a specific load capacity. If the load—caused by excessive weight or uneven assembly—is distributed unevenly across individual connections, the material can loosen over time.
Additionally, the preparation of the dowel holes plays a role. If the holes are not drilled precisely or are too large, the dowel will not fit tightly enough, which can promote loosening. Temperature fluctuations and humidity can also cause the wood materials to expand or contract, affecting stability.
JONSON schrieb:
Temperature fluctuations and humidity can cause wood-based panels to expand or contractThat is exactly correct and should not be underestimated. I have conducted a systematic check on several assemblies to see how the joints react when the humidity rises above 60% humidity. The particleboard material, from which the BILLY shelves are typically made, is indeed quite sensitive to moisture content.
Therefore, I recommend the following:
1. Before assembly, all panels should be acclimated to room temperature and normal humidity conditions.
2. The holes for dowels and screws must be drilled as precisely as possible, since tolerances in particleboard can affect the strength of the connection later on.
3. If necessary, use additional adhesive or special locking compounds for screws to prevent loosening due to slight vibrations or movement.
I would be interested to know if you have the shelves placed in a location subject to strong climatic fluctuations? More information would help to narrow down the cause more precisely.
Dilen schrieb:
I’m curious if you have the shelves placed in a location exposed to significant climate fluctuations?Good question! The shelves are mostly located in living areas, so not really damp, but also not climate-controlled – maybe older buildings with some variation in humidity, especially in summer and winter. I installed them exactly according to the instructions, including tightening the Minifix screws, but maybe something has loosened over time.
Regarding the adhesive: What exactly do you mean? Wouldn’t that void the warranty if I try to fix it myself? Are there any tips on whether that might be useful or possibly even harmful?
I’m also interested in hearing other opinions.
Gojakin schrieb:
Regarding adhesives: What exactly do you mean? Wouldn’t the warranty be void if I try to fix it myself?Using adhesive doesn’t mean “gluing everything wildly” – I’m talking about something like a small drop of wood glue inside the dowel holes before inserting the dowels. It hardens and ensures optimal grip without damaging the components. Usually, the warranty isn’t an issue as long as you don’t completely rebuild or damage the furniture.
Also:
JONSON schrieb:
The fasteners are designed for a specific load capacity.This is often underestimated! Sure, BILLY is great, but it’s not an off-the-shelf heavy-duty shelf. If you overload the shelves or use them as a ladder, everything will end up wobbling. So better to be careful with the weight – and check every now and then if the screws are still tight.
And very important: If something wobbles, don’t just tighten it – first check all connections thoroughly. That saves frustration and hate for your tools 😉 🙂
