ᐅ Why do screws in BILLY bookcases loosen so quickly?
Created on: 19 Apr 2020 09:13
Senagla
I wanted to raise a specific question that has been on my mind for a while: Why do screws in Billy shelves seem to come loose so quickly, sometimes after just a few weeks or months of use? I’ve noticed that especially with certain models, the small manufacturer’s screws—often used to attach shelves or back panels—eventually lose their grip, causing the shelf to become wobbly or parts to shift.
I follow the instructions exactly and don’t apply excessive load. However, this issue seems to occur systematically; I’ve heard similar reports from friends and seen many accounts online. I’m wondering whether it’s related to the material, assembly method, design, or something else.
Does anyone here know about this problem and can explain what causes it? Are there any practical tips to prevent it? I’d appreciate knowledgeable responses.
Katau
20 Apr 2020 09:02
On this topic: The problem is common in the DIY and furniture industries, not just with BILLY. Particleboard is simply not ideal for lasting screw connections.
That’s why many manufacturers use dowel joints, metal fittings, or cam-lock systems. These improve stability but increase production and assembly costs.
If you want stability, you should consider retrofitting such fittings or additional brackets if the screws start to loosen.
Nils58
20 Apr 2020 09:56
Katau schrieb:
That’s why many manufacturers use dowel joints, metal fittings, or cam lock systems.
Exactly! I did it that way myself and added a few extra brackets and metal connectors. It’s a bit of simple DIY, but it holds extremely well! 🙂 Sure, it takes a bit more time, but the result is definitely worth it.
GALEO4
21 Apr 2020 10:17
I am always amazed at how much effort people put into cheap shelving units. You can solve the problem with screws – or you can accept that BILLY shelves are not designed for heavy loads and choose higher quality furniture for long-term use.
Some expectations for budget products are simply unrealistic. This should be considered before turning to screws and glue.
bente
21 Apr 2020 10:39
GALEO4 schrieb:
Some expectations for cheap products are simply unrealistic.
That's true, but it's also natural to want to enjoy your furniture for a long time.
Maybe the compromise is to accept that budget shelves won’t last forever, while taking small steps to extend their lifespan – that helps me at least to be less frustrated. 🙂
