Gautammam6 Jun 2024 09:13I have recently noticed an increasing number of cases where screws loosen on their own in various applications, even though they were installed correctly. This raises a fundamental question for me: Why do screws actually loosen? I suspect there are different influencing factors, such as material properties, installation methods, or dynamic loads, but environmental conditions could also play a role. What physical or mechanical processes cause screws to become loose, even if they were initially tightened properly? And what methods exist to reliably prevent this from happening?
The main reasons screws loosen are usually vibration loads, thermal expansion, and insufficient preload.
Vibrations can reduce the friction between the screw thread and the nut, causing the screw to gradually loosen. Thermal expansion mainly affects the connection when the screw and the material have different coefficients of thermal expansion.
In addition, assembly errors play a significant role: applying too low a tightening torque results in insufficient preload to securely hold the joint.
Preventive measures that have proven effective include locking devices such as spring washers, adhesives, or specialized nuts that prevent loosening. Applying the correct tightening torque while considering the combination of materials is also crucial.
The process behind why screws loosen can be explained through biomechanical principles, especially when considering the screw connection as a preload system. After tightening, a preload force is generated in the screw, which clamps the components together.
This preload force is crucial for the strength of the connection. If it is reduced due to factors like vibrations, varying loads, or temperature changes, relative movement occurs between the screw and the nut. This further reduces the preload force – a cycle that ultimately leads to the screw loosening.
This statement is correct; however, I would like to add that the “loss-of-tightness” theory must also be taken into account. It states that even very small micrometer-scale displacements in the threads reduce the preload force.
I’m curious about the specific screw size involved and the environment in which these issues occur. Different physical principles apply to larger screws compared to smaller ones, and the impact of environmental conditions varies significantly.
Also: How is the assembly process currently performed on your side? Do you use a torque wrench or other tools?
pikin schrieb:
"Vibrations can cause the friction between the screw threads and the nut to decrease"
Gautammam schrieb:
"So my basic question is: Why do screws actually come loose?"Let’s be honest: screws are not designed to stay absolutely tight forever. Almost every screwed joint is subject to physical forces that sooner or later cause loosening.
The constant talk about ‘proper installation’ is important, but often overrated. Even with maximum torque, material fatigue, micro-movements, or even thread fatigue will eventually force the screw to loosen.
So aren’t we just too dependent on the illusion that screws can be fixed permanently? Why does nobody seem to consider alternative fastening methods anymore, if screws inevitably come loose? A bit of provocation: maybe all these locking devices are just a luxury for the industry, covering up practical problems and user errors.
To comprehensively answer the question "Why do screws loosen?" I would like to provide a brief guide for better understanding and prevention of screw loosening:
1. Basics: Screws function through preload tension that holds a joint under pressure. This tension is created by tightening but can change due to mechanical and thermal influences.
2. Loosening mechanisms:
- Dynamic loads such as vibrations cause micro-movements in the thread.
- Thermal cycles lead to different expansions of the screw and the component.
- Corrosion can damage the thread and reduce friction.
3. Common mistakes:
- Under- or over-tightening torque during installation
- Lack of use of locking measures
- Improper use of screw materials
4. Prevention measures:
- Mechanical locking devices: spring washers, locknuts
- Chemical locking agents: thread lockers (e.g., Loctite)
- Design solutions: keys, locking washers
This is correct; it depends on the specific application. For continuous loads, there are specialized solutions, for example, positive-locking joints that can supplement screws.
I am happy to elaborate on individual aspects or provide tips on selecting appropriate locking methods – of course, this depends on the application! :-)
3. Common mistakes:
likuken schrieb:
"Even at maximum torque, material fatigue ... can ultimately force loosening."
