ᐅ Why do screws come loose in BILLY furniture despite careful assembly?
Created on: 20 Nov 2023 14:27
BrockdeoI have a quite specific question: Why do the screws on Billy furniture keep loosening, even though the assembly is done very carefully and according to the instructions? Specifically, I tightened all screws evenly with the appropriate tool using medium torque, yet some joints noticeably loosen after just a few weeks of use. I am especially interested in whether this could be due to material properties, assembly methods, or everyday influences. I would also appreciate any tips on how to solve this problem permanently without damaging the furniture.
The phenomenon of screws loosening in BILLY furniture despite correct assembly is, in my view, often due to the materials used and the construction. BILLY furniture is mainly made of particleboard or fiberboard, which provide limited grip for screws as fastening materials. The screws are not anchored in solid wood that can deform or contract, but in panels with limited strength.
Additionally, stresses from everyday use, vibrations, or slight movements cause the screws to gradually develop play. Another issue is the short and thin screws frequently used by IKEA, which limits the durability of the connections. To address this, combinations of threadlocker or larger fasteners can help improve the connection stability.
In addition to the points already mentioned, I would like to emphasize that the construction of BILLY furniture is designed for modular simplicity, which limits the material thickness and screw length. This mechanically restricts the holding strength of the connection.
Another factor is the tensile strength of the screws and the board material under dynamic load, as typically occurs in use. Repeated stress reduces the friction that fixes the screw position, which promotes slow loosening.
From a technical perspective, the best solution is to use screw locks or occasionally re-tighten the connections to maintain an even load.
Here is a brief guide on how to address the issue of loosening screws in BILLY furniture.
1. Preparation: During assembly, make sure the screws are inserted straight and tightened neither too firmly nor too loosely.
2. Use threadlocker: Applying a drop of medium-strength threadlocker on the threads prevents the screws from loosening.
3. Follow-up inspection: Check the furniture after a few weeks and retighten screws if necessary.
Common mistakes include overtightening, which can damage the material, and undertightening, which causes movement. In my experience, screws secured with threadlocker hold best.
I can easily understand the frustration when screws come loose despite being installed correctly. This often happens because the panel materials (chipboard) expand and contract slightly due to moisture and temperature changes, which can cause even well-driven screws to become loose.
It is helpful to assemble the furniture in its final location and avoid moving it too much. Additionally, a regular check after 2-3 months can work wonders.
Please also avoid tightening the screws too much, as this can easily damage the material. A moderate tightness is the best compromise.
From a technical perspective, this issue is more complex than it appears. BILLY primarily uses thin particle boards, which do not provide high withdrawal resistance for screws. The stressed areas are often only a few millimeters thick.
This causes screws to lose their holding strength under repeated load changes because the wood veneer around the threads can easily delaminate or break out. The usual screw locking method is primarily a friction enhancement, which sometimes is insufficient.
I recommend using threaded inserts (such as Røver or Heli-Coil) or alternatively furniture connector wing nuts, to better distribute the forces acting on the screws.
Yes, all of these factors play a role. I would be interested to know if your furniture is subjected to specific stresses like tension or tilting movements, as that can influence the solution.
Brockdeo schrieb:
ist das möglicherweise an Materialeigenschaften, Montageprinzipien oder Einwirkungen im Alltag liegen könnte
