ᐅ Why do MALM furniture pieces wobble even when assembled correctly?
Created on: 27 Jun 2024 18:13
gotelaHello everyone, I recently assembled several MALM furniture pieces (especially dressers and nightstands) and carefully followed all assembly instructions, tightening all screws properly and securely, and using the included dowels and fittings correctly. However, I have noticed that some of these furniture items still wobble or feel somewhat unstable despite proper assembly, especially when lightly bumped or pressure is applied.
My question is: Why do MALM furniture pieces wobble despite correct assembly? Are there common causes to consider or fix in advance to improve stability? Could it be due to material properties, design details, or perhaps assembly tips that are often overlooked?
I would appreciate any helpful insights and practical experiences!
Hello gotela,
I understand your question well and would like to give you a brief overview of common reasons why MALM furniture often wobbles, even when everything is correctly screwed together:
1. Back panel attachment: MALM dressers often have a thin back panel that is fixed with small nails or screws. If this panel is not completely flush or is slightly loose, the furniture can wobble and appear unstable.
2. Side panel to shelf connections: The connections made of particleboard or MDF are assembled using dowels plus screws. If the dowels are not fitted perfectly or the screws are not fully tightened, this can cause some play.
3. Leg installation: Even on the same floor, the angle of the legs may sometimes not be exact, especially with individual nightstands that have small base areas.
4. Material properties: MALM is often made of coated particleboard, which does not have the same stability as solid wood. This results in a certain flexibility, which can show as “wobbling.”
My tip: Specifically check the back panel for damage and a firm fit, systematically retighten all screws, and try to place the furniture on the most level surface possible. If the back panel moves slightly, you can try to secure it further with small wooden strips.
Summary:
- Check the back panel
- Inspect screws and dowels
- Adjust the legs
- Measure the floor level
This should help you get closer to solving the problem.
Summary:
- Adjust the legs
Jensson schrieb:
Back panel attachment: MALM dressers often have a thin back panel that is attached with small nails or screws.That’s exactly right. If the back panel is not secured tightly, the entire piece of furniture will wobble.
flo-Theres29 Jun 2024 08:19If you have followed all assembly instructions carefully, the wobbling might still be due to a few details despite correct installation:
First: MALM furniture is made from laminated chipboard, which can react to moisture by swelling or slight warping. This can cause some movement.
Second: The back panel, as mentioned before, also serves as a stabilizing element. Since it is often very thin and only fixed at the edges, small movements are normal, especially if the furniture is not firmly placed against a wall or secured with wall fasteners.
Third: A very common factor is the floor on which the furniture stands. It often makes sense to use small furniture pads or felt protectors to compensate for slight unevenness in the floor and thereby reduce wobbling.
Finally, a tip: If possible, use wall fasteners for additional stability. This is not only for safety reasons but also to keep the furniture steady.
I hope this helps you.
