ᐅ Why do Malm furniture pieces become wobbly after extended use?
Created on: 20 Jan 2021 07:43
NautyrellN
Nautyrell20 Jan 2021 07:43Hello everyone,
I have noticed that some of my IKEA Malm furniture, especially wardrobes and dressers, start to become wobbly after extended use. I am curious about the reasons behind this.
I suspect it could be related to the design or the materials used, but assembly errors or wear and tear might also play a role.
Could someone explain the mechanical or structural causes that lead to this wobbling? And are there ways to fix the issue with minimal effort?
I would appreciate detailed and technically informed answers, as I would like to better understand the problem in order to address it effectively.
Hello Nautyrell,
to answer your question about why Malm furniture tends to wobble after extended use, I can explain this in a bit more detail.
1. Material and construction: Malm furniture is made from particleboard covered with a thin wood veneer layer. This material is prone to slight deformation, especially when it absorbs moisture or is subjected to weight over a longer period.
2. Assembly system: These types of furniture are often assembled using connecting dowels, bolts, and so-called Minifix locks. If these connections no longer fit properly over time or have loosened due to movement, it results in instability and wobbling.
3. Load and wear: Constant use, for example with drawers that are frequently opened and closed, can loosen screws or connectors. Using the furniture on uneven floors can also apply additional forces.
4. Assembly errors: If the furniture was not aligned correctly or screws were over-tightened or not tightened enough, this increases the risk of movement.
Tips to fix it:
- Check all screws and connectors and tighten them if necessary.
- If needed, place thin pads under the furniture feet to ensure a level standing surface.
- Avoid placing excessive load on individual points.
In summary: wobbling usually occurs due to loose connections or material deformation.
If you like, I can send you a checklist to help you inspect your furniture step by step.
Tips to fix it:
To complement the previous posts:
Wobbly Malm furniture results from the mechanical wear of the fasteners that ensure structural integrity.
Compared to solid wood, particleboard is more sensitive to stress and moisture, which can cause swelling and slight dimensional changes. This leads to originally tight connections becoming loose.
Additionally, screw loosening over time due to cyclic loading is a common issue. In designs that heavily rely on form-fitting joints such as cam locks (Minifix) or dowels, the risk of wobbling is significantly increased.
To fix this, it is essential to check and tighten all screw connections. If possible, applying wood glue at the joints can help reduce play. For damaged or heavily worn connectors, replacement parts are recommended.
Finally, it should be considered that the lifespan of this type of furniture is limited by its construction. Completely solid and permanently wobble-free stability cannot always be guaranteed with affordable furniture of this kind.
kemads46 schrieb:
Wobbling usually occurs due to loose connections or material deformation.That sums it up well. I would like to add that with furniture like Malm, small movements accumulate over time, which especially affects drawers and doors, causing more play.
It's also important to note that depending on the indoor climate, wood-based materials can slightly expand or contract. This additionally influences the fit of the joints.
A simple method I often recommend is systematically tightening all screws one at a time, not all at once, but step by step, to gradually restore the furniture to its original tension.
It is also essential to check whether all furniture legs are evenly resting on the floor. For uneven floors, special furniture pads or felt glides are very helpful.
If wobbling persists after these measures, you can secure the connection points with wood glue or, if necessary, add reinforcements such as small brackets inside to increase stability.
If you need specific advice on how to proceed, I’m happy to help.
