ᐅ Why do Malm beds develop wobble or looseness after extended use?
Created on: 25 Jan 2020 18:37
gottholdko
gottholdko
25 Jan 2020 18:37
I have a question that probably concerns some of you who have been using an Ikea Malm bed for a longer period: Why do Malm beds develop a certain looseness or wobbliness over time?
I don’t mean the usual slight give when sitting down, but a noticeable shaking or creaking of the structure—often at the joints between the slatted frame and the bed frame or at the corner connections of the side panels with the headboard or footboard.
I’m interested in understanding the exact cause. Is it due to the choice of materials, the fastening technique, wear of certain components, or possibly repeated assembly and disassembly or assembly errors?
I know Malm beds are relatively affordable compared to others, but is this looseness normal after 3–5 years, or can it be permanently prevented by tightening, reinforcements, or similar measures?
I look forward to your experience and technical explanations.
flo56
25 Jan 2020 19:16
The most common cause of looseness in Malm beds after prolonged use is the combination of materials and connection techniques.
Malm beds are primarily made from particleboard or MDF with a decorative laminate. These materials are less durable against constant stress and mechanical strain compared to solid wood. Additionally, the fasteners are usually metal dowels and screws, which can become looser over time in engineered wood products.
Another point:
gottholdko schrieb:
Often at the joints between the slatted frame and the bed frame or at the corner connections of the side panels and headboard/footboard
These areas are subject to particularly high static loads. Due to the load cycles (sitting down, turning over, getting up), the material gradually changes, and the connections can shift slightly or wear out.
Tightening the screws can help temporarily but does not provide a permanent solution if the particleboard is already frayed.
In summary: The looseness is caused by material fatigue and wear of the fasteners. For lasting stability, a construction using solid wood or metal connectors would be more suitable.
anno58
26 Jan 2020 08:47
In addition to what flo56 mentioned, I would like to add something about the assembly process. Especially with this type of construction using particle board, correct and careful assembly is crucial for the long-term stability.
If the screws are tightened too much or too little during assembly, it can damage the material. Over-tightening can cause the particle board to crack or the screws to strip out, resulting in looseness later on. Screws that are too loose create a wobbly structure right from the start.
Furthermore, length changes due to temperature and humidity fluctuations can slightly alter the tension of the joints. While this is not very noticeable in everyday use of a bed, it can become apparent over several years.
flo56 schrieb:
Retightening screws can help temporarily but does not have a lasting effect if the particle board is already frayed.
That sums it up well. If the material is damaged, replacement or reinforcement with additional fasteners is often the only solution.
Those with some DIY skills can, for example, add small wooden dowels or attach metal brackets for reinforcement. This can stabilize the bed and significantly reduce any looseness.
jaanda
27 Jan 2020 14:52
In summary, looseness in a Malm bed after extended use is mainly caused by the following factors:
1. Material properties: Particleboard and MDF are not designed for permanent, dynamic tensile and shear loads. Over time, fatigue occurs.
2. Fasteners: Screws and dowels lose their grip when the substrate material is damaged or frayed.
3. Load concentration points: Corner joints and slat frame supports are especially stressed structurally.
4. Assembly quality and maintenance: Improper assembly or frequent retightening without adding reinforcements promotes looseness.
Preventive measures cannot completely eliminate the problem if the original construction is retained.
I recommend conducting a visual inspection of all joints after 3–4 years, checking the screws, and applying small reinforcements with metal brackets or wooden strips at the first signs of looseness. These steps significantly extend the lifespan and stability.
This way, the basic structure is preserved and quickly increasing loosening is avoided.
