ᐅ Why are some BILLY shelves more prone to scratches?
Created on: 19 Aug 2023 19:03
Rusijo
Rusijo
19 Aug 2023 19:03
I have a question that has been on my mind for a while: Why are some Billy shelves more prone to scratches than others?
I own two units that look very similar, but one shows signs of wear and scratches much faster and more noticeably, while the other still appears almost unscathed.
I have considered whether it might be due to different production batches, the material, or the manufacturing process, but I don’t know the exact reason. Perhaps the surface coating or how the shelves are used also plays a role.
Does anyone here have experience with this or know why some BILLY shelves seem more susceptible to scratches? I would really appreciate detailed explanations or tips on how to better protect the shelves.
Jukin
19 Aug 2023 19:47
Hello Rusijo,
Your observation is completely understandable. BILLY shelves do indeed come in different production batches and materials, which can affect their scratch resistance.
There are different surface types: some shelves have a melamine resin-coated surface, which is especially durable, while others only have a foil coating that may be less resistant.
Additionally, the production year and material thickness play a role. Older models can be more prone to damage because the protective layers were thinner or of lower quality.
How the furniture is handled also affects wear: fine scratches appear from rough treatment or when heavy objects are dragged across the surface without protection.
In summary, I would say that varying materials and coatings, along with everyday use, are the main reasons for increased scratch sensitivity in BILLY shelves. Careful handling and targeted protection help preserve the surface.
peovin
19 Aug 2023 20:12
It is usually due to the surface finish. Some BILLY shelves have laminated surfaces, which are easier to scratch than those coated with melamine resin. Age and usage are also important factors.
teyosef
20 Aug 2023 08:34
Jukin schrieb:
Different materials and finishes, as well as ease of use, are the main reasons for higher scratch sensitivity in BILLY shelves.
I would like to explain this in a more structured way:
1. Different surface types: The most common cause is varying surface types, such as foil versus melamine resin. Foils are thinner and more prone to mechanical damage.
2. Production batches: Over time, IKEA optimizes materials and coatings, which can result in differences in quality.
3. Wear from use: Depending on how the shelf is used—for example, placing heavy or sharp objects on it—scratches can develop more quickly.
4. Cleaning: Using the wrong cleaning agents can damage the surface and increase its vulnerability.
5. Environmental factors: Humidity and temperature fluctuations can affect the material and weaken the protective layer.
My advice: To protect the shelf, use appropriate cleaning methods and, if necessary, apply felt pads or protective mats to shelf edges or surfaces. This helps prevent unnecessary scratches.
Rusijo
20 Aug 2023 09:05
teyosef schrieb:
Depending on how the shelf is used—such as placing heavy or sharp objects on it—scratches can appear more quickly.
Thank you for the clear explanation! I hadn’t really considered it in such detail before.
I’m also interested to know if there are any recommendations or tips for the proper care of BILLY shelves?
Are there specific cleaning products that I should definitely avoid to prevent damage to the surface?
And what about touching up minor scratches—is there any practical method that can be done by oneself?
benon
20 Aug 2023 10:22
Rusijo schrieb:
Are there specific cleaning agents I should definitely avoid to prevent damaging the surface?
Hello Rusijo,
Yes, in general, you should avoid harsh cleaning agents, abrasive sponges, or alcohol-based cleaners. These can make the surface more vulnerable or even cause discoloration. It’s better to use mild soapy water and soft cloths.
For touching up small scratches, special furniture markers are a good option. They are available for laminated and melamine resin-coated surfaces and can be very effective visually by matching the color and tricking the eye.
For larger damage, repair kits with filler and touch-up paint pens are also available, but these are more involved and less straightforward for DIYers.
Regular maintenance is also important to preserve the protective layer and keep the appearance looking good for as long as possible.
