Hello everyone, I am currently looking into the topic of IKEA BILLY bookcases and have made a specific observation: Why are some BILLY bookcases more prone to damage and deformation than others? I have the impression that this is not only due to improper use or assembly but that different production batches or material qualities might also play a role. You often read about customers whose bookcases become unstable or scratched after a short time, while others have used their BILLY for years with almost no signs of wear. I am particularly interested in which factors – ranging from the type of wood or particleboard, the surface finish, the manufacturing quality, to the assembly instructions – might truly affect this sensitivity. Has anyone in the community had similar experiences or even firsthand information? I would appreciate a detailed explanation and assessment.
I find your topic interesting because it goes beyond the usual superficial treatment found in typical furniture reviews.
That sounds reasonable at first, but I would like to see evidence. In my opinion, IKEA has very strict quality controls regarding varying material qualities. On the other hand, particleboard is naturally more susceptible to moisture and mechanical stress. A crucial factor could also be how the product is stored by the customer: varying humidity levels and incorrect assembly techniques can quickly weaken it.
Furthermore, I have noticed that the surface finish—whether laminate or paint—is often underestimated. A rougher finish usually offers better protection against scratches, while glossy laminates show marks more easily. Have you noticed that as well?
I’m skeptical that production batches are the main factor, but I’m open to being convinced.
Blakla schrieb:
I have the feeling that it’s not just improper use or assembly, but that different production batches or material qualities might also play a role.
It’s quite clear: installation errors and improper handling are usually to blame. Not every wall is perfectly straight, so shelves must be precisely aligned. Another important point: do not exceed the maximum load capacity. Particle boards weaken quickly when wet, which is normal. The material itself is always the same with BILLY. Those who assemble carefully and maintain the shelves properly will not have any problems.
The difference in sensitivity of the BILLY shelves can be attributed to several factors, and I would like to explain this in more detail.
First of all, BILLY shelves are actually made from wood-based panels, often particleboard, which is covered with a foil. These materials can vary slightly depending on the production year – IKEA sometimes uses different suppliers, which can result in minor differences in density and the fineness of the particleboard.
Assembly also plays a significant role: if screws are not tightened properly or brackets are not precisely adjusted, the shelf can become unstable and sustain damage more quickly. In particular, the connecting strips and back panels are crucial for stability.
The environment, meaning humidity and room temperature, also affects sensitivity. A BILLY shelf in the bathroom is exposed to more moisture stress than the same model in the living room.
This is usually true, but small variations occur due to different production batch sizes, which often only become noticeable after several years.
In summary: production, assembly, usage, and environmental conditions make the difference.
barda6 schrieb:
Material itself is always the same for BILLY.
I can relate to this well because I also have BILLY shelves that react differently. Some are very durable, while others get damaged easily.
Honestly, this has been a bit frustrating for me too, as I actually appreciate the shelves a lot. Sometimes I felt like it’s just bad luck with the manufacturing or even transport damage – things you can’t control.
It helps to handle the shelf carefully during assembly and avoid stacking items that are too heavy on it. But yes, there are times when you need to pay close attention and possibly adjust or replace parts.
A question for the original poster: Have you noticed any differences in the materials yourself? And how has your experience with the assembly been? That might shed some light on things 🙂
elgla schrieb:
Honestly, I found this a bit frustrating too, since I actually appreciate the shelves a lot. I think this honest perspective is important, as it shows that the issue involves not only technical but also emotional factors.
Additionally, I would like to clarify once more that the topic of "differences in sensitivity" is by no means just a matter of “bad luck in production.”
I have often read in forums that different back panels (MDF instead of particleboard) are used depending on the model and production year. This can significantly affect stiffness.
Furthermore, adhering to the allowed load limits is not only important in theory but also has practical consequences. Even a few extra kilograms on higher shelves can cause everything to wear out faster.
So who at IKEA designs the tolerances for this? Do you also notice that older models often seem more robust? Perhaps the materials have become somewhat thinner over time and, as a result, more vulnerable?
