ᐅ Which tools are needed for more complex modifications of Ikea Hemnes furniture?
Created on: 19 Feb 2021 18:37
Simin66Hello everyone, I am planning a somewhat extensive remodeling project involving an Ikea Hemnes cabinet and want to gather detailed information in advance on which tools are truly useful and necessary to carry out more advanced modifications safely and neatly. I am particularly interested in which tools—beyond the usual basics like screwdrivers and drills—have proven effective for tasks such as precise cutting of panels, attaching reinforcements, possibly drilling for special fittings, or even conversions where parts are repurposed. Which tools are needed for more complex Ikea Hemnes modifications? Are there any special recommendations, especially when working to harmonize different materials like solid wood, MDF, and veneer? I look forward to your tips and practical experience!
For more advanced Hemnes modifications, you will definitely need a cordless drill/driver as well as a fine jigsaw, preferably with an adjustable orbital action. Sandpaper or a random orbital sander helps to finish edges smoothly. A level guide rail is also invaluable if you want straight cuts.
Hello Simin66, your question is very well formulated and to the point – thank you for also addressing the variety of materials. If you are planning complex modifications to the Ikea Hemnes, I recommend the following tools and aids:
- A precise cordless drill with various bits. Since Hemnes often uses MDF and veneered surfaces, you definitely need drill bits with special spiral or flat edges to avoid chipping.
- A jigsaw with a fine-toothed blade. A guide rail or stop is very helpful to ensure straight and clean cuts, especially with the thin panels.
- An orbital sander can effectively smooth out small unevenness and cross-angles, which often occur with new or modified materials.
- A cordless screwdriver that feels comfortable in your hand and can handle longer screws without difficulty.
- For precise marking and positioning of drill holes, a good spirit level as well as a sharp pencil or marking gauge.
If you are working with solid wood components, chisels might also be useful, but make sure they are sharp to avoid damaging the veneer.
Very important: Take your time measuring and mark all cut and drill points carefully before you start. This helps prevent costly mistakes. Good luck with your project!
dosogau schrieb:
For more complex Hemnes modifications, besides a cordless drill/driver, you definitely need a fine jigsaw, preferably with an adjustable orbital action.I completely agree. I faced the challenge of modifying a Hemnes chest of drawers myself and that was my first experience using a jigsaw. At first, I was uncertain, especially when cutting veneered surfaces, since it’s easy to chip – but with a proper saw, a fine-toothed blade, and above all the right guidance, it was manageable.
Laurence schrieb:
- A jigsaw with a fine blade. A guide rail or stop is very helpful to ensure the cuts are straight and clean, especially on thin panels.I can only confirm that! Additionally, I would add that when drilling holes for special fittings, you need high-quality drill bits. During my first modification, I used bits that were too coarse and ended up damaging the MDF edges – very frustrating.
In my opinion, for more demanding modifications, you shouldn’t skimp on the right tools. It’s really worth investing in good quality to avoid frustration and extra work.
For those who modify furniture relatively often, I also recommend a sturdy workbench with clamps. This makes it easier to secure the piece and allows for cleaner and safer work.
What about you? Who has experience with alternative tools or tips for Hemnes modifications?
