ᐅ Which replacement parts for Billy are easy to change yourself?
Created on: 25 Feb 2021 08:17
todulau
todulau
25 Feb 2021 08:17
I would like to know which replacement parts for IKEA Billy shelves can be relatively easily replaced without requiring special tools or prior DIY experience. I am especially interested in whether damaged screws, shelves, or even the back panels can be replaced without much hassle. It would be helpful if you could also briefly explain the best approach and what to watch out for to avoid any stability issues afterwards. Thanks in advance for your tips!
Pome60
25 Feb 2021 09:23
todulau schrieb:
Which replacement parts for Billy shelves from IKEA can be relatively easily replaced by yourself without special tools or prior DIY experience.
It’s great that you bring up this topic! 🙂 I find that shelf boards are especially easy to replace. IKEA sells those individually, and usually all you need is a screwdriver, often just the included Allen key.
Screws can usually be replaced easily as well; I’ve bought sets before that fit perfectly. The back panels can be a bit tricky, but with a small hammer you can usually remove and reinstall them without much trouble. You’ve got this! If you need any tips, just ask :-)
Lisele
25 Feb 2021 10:05
I understand that people like to do DIY work on Billy shelves. However, I was a bit concerned about whether stability can be sufficiently ensured when replacing parts with little experience.
Pome60 schrieb:
Back panels can be a bit tricky, but usually a small hammer works well to remove and reinsert them.
I find that somewhat risky, especially if several children or heavy items are placed on the shelf. Which parts have you already replaced, and how did you make sure the shelf didn’t lose stability despite the replacement?
hauklo
25 Feb 2021 11:40
To the point: The most common replacement parts for Billy shelves that users replace themselves are shelves, screws or fittings, and the back panel.
Shelves are very easy to replace since they simply rest on metal pins and do not require glue or screws. You just remove the old shelf, place the new one on the pins — done.
Screws and connecting fittings can be replaced but require as accurate a size as possible. IKEA usually offers spare parts online or through their customer service hotline.
The thin back panel is fixed with small nails that can be removed and reattached with a small hammer — caution is advised here to avoid splitting the wood.
Tools: A good Phillips screwdriver and a small hammer are sufficient; no special tools are needed. Repairs to load-bearing parts are rarely necessary unless the shelf is heavily damaged.
fepau
25 Feb 2021 12:58
hauklo schrieb:
Shelves are completely easy to replace
Oh yes, I totally agree! 🙂 Last week I replaced my scratched shelf without any problems – it was done quickly. Just unscrew the pins, put on the new shelf, and screw the pins back in.
It’s great that you don’t have to buy a whole new unit! If you’re a bit careful, this works with any Billy shelf. Good luck, I’m sure you’ll manage! 🙂
Parbo
25 Feb 2021 14:33
To thoroughly answer todulau’s question, I recommend a detailed look at the individual replacement parts:
1. Shelves: As mentioned before, these are the easiest to replace. It is important to order the correct shelf in the right size, as Billy models vary (e.g., width and depth). The metal pins must be undamaged since they support the load.
2. Screws and connectors: These are usually standard sizes, but sometimes there are special IKEA-specific parts. It is advisable to remove individual damaged screws before replacement and compare them at a hardware store.
3. Back panels: These are made of thin hardboard or thin MDF. Due to the nail fastening, removing them must be done carefully to avoid breaking the material. For replacements, it is recommended to purchase precise fits from IKEA or third-party suppliers.
4. Side panels and support pieces: These are more challenging and should only be replaced if you have experience and the right tools (cordless drill, center punch).
If you want, I can also provide a small step-by-step guide on how to replace a shelf and keep the unit optimally stable. Do you need that?
