ᐅ Which soft-close systems can be easily retrofitted to Ikea BESTA doors?
Created on: 25 Aug 2017 13:07
sianleo
sianleo
25 Aug 2017 13:07
Hello everyone, I am planning to retrofit a soft-close system on my already installed Ikea Besta cabinet doors to prevent them from slamming shut. Since Besta doors tend to be lightweight and often use clip-on hinges, I am wondering which soft-close systems can be easily integrated without much effort. Important factors for me are compatibility with the original fittings, simple installation, and preferably no major modifications to the door or the cabinet frame.
Does anyone here in the forum have specific soft-close solutions that can be used plug & play with Besta cabinets? Are there perhaps retrofit kits developed specifically for Ikea Besta? Or is it necessary to replace the hinges with universal ones or make other technical adjustments? I look forward to hearing about your experiences or recommendations, ideally including notes on installation and costs.
Laukau5
25 Aug 2017 14:36
sianleo schrieb:
Does anyone here in the forum know of specific soft-close solutions that can be used plug & play with BESTA cabinets?
Hello, I can draw on a fair amount of experience here, so I’ll provide a somewhat detailed response.
The BESTA series from Ikea typically uses clip-on hinges with integrated locking mechanisms, which makes it possible to retrofit soft-close systems either by replacing the hinges or by adding external soft-close dampers.
- Replacing the hinges: The simplest and most straightforward solution is to switch to soft-close door hinges that fit the mounting plate system and the drill holes of the BESTA cabinet doors. You should choose hinges that do not alter the 35mm (1.4 inch) drill holes on the doors and maintain the same mounting principle. Products from manufacturers like Blum or Hettich often offer suitable soft-close options. However, this approach requires completely replacing the hinges.
- Adding auxiliary dampers: There are also universal soft-close dampers that can be mounted on the cabinet carcass or near the hinges. These include magnetic or spring-damped systems, which usually require an additional hole or adhesive points. This method generally involves less effort than replacing the hinges but may be less durable and not as quiet.
One tip: When installing, make sure the doors are precisely aligned. Especially with retrofits, improper adjustment can affect closing performance or make the damping ineffective.
Therefore, please let me know if you are confident with the tools you have and whether the doors are already heavily worn, so we can assess how durable the retrofit is likely to be in the long term.
GLALEO
26 Aug 2017 09:42
Hey, very interesting topic! 😊 A few months ago, I retrofitted a soft-close system on my BESTA doors by directly replacing the original hinges with soft-close models from Blum.
Laukau5 schrieb:
The BESTA series from Ikea usually uses clip hinges with integrated locking mechanisms, which allows retrofitting soft-close systems either by replacing the hinges or by using external additional dampers.
I can confirm this from my own experience! The replacement was quite easy because the new soft-close hinges have exactly the same drill holes. The doors can still be unclipped and adjusted as usual. I would definitely recommend choosing this option if you value consistently smooth closing performance.
If you have some DIY skills, this is a really great option. And don’t worry: it’s not expensive and will last for many years!
Tarmau
27 Aug 2017 11:58
GLALEO schrieb:
The replacement was quite straightforward because the new soft-close hinges have exactly the same drill holes.
To add: Compatibility of soft-close hinges with Ikea BESTA cabinets usually only works with standard-sized hinges (35 mm cup drilling, 37 mm mounting depth). When purchasing third-party hinges, it is important to ensure they match these exact dimensions and mounting points to avoid rework.
There are some manufacturers whose hinges fit directly as replacements, including Blum Clip Top BLUMOTION models. In these cases, the original mounting plates of the BESTA cabinet doors can be used. These plates are designed for press-fit mounting, allowing easy removal and installation.
sianleo schrieb:
Are there perhaps retrofit kits specially designed for Ikea BESTA?
I am not aware of any soft-close retrofit kits specifically designed for BESTA that work without changing the hinges. Universal soft-close dampers are mostly used on simpler furniture but are rarely an ideal solution for furniture with clip hinges and high usability standards.
In summary, replacing the hinges is the most durable and reliable option.
Far34
28 Aug 2017 08:15
For most Ikea BESTA doors, I recommend replacing the hinges with Blum soft-close hinges. This is the cleanest solution and the easiest to install. Additional dampers are often unreliable and less precise.
If the doors are very lightweight, hinges with a damping mechanism specifically designed for small doors should be used.
