I am currently assembling my IKEA Besta cabinet and have noticed that there are several types of screws and fasteners that look quite similar at first glance. To avoid mistakes that could later affect the stability or function, I would like to know: Which screws absolutely must not be mixed up during the assembly of the IKEA Besta?
I am especially interested in whether there are parts that look very similar but have different lengths or head types, which could make incorrect assembly risky.
Perhaps someone has a detailed overview or knows common errors to avoid when dealing with the mix of screws. Thanks in advance for the help!
The most important distinction between screws in the BESTA system is usually between the connector bolts (dowels with screw threads) and the cylinder head screws with internal hex drives.
- Connector bolts are generally slightly thicker and are screwed into pre-drilled holes to securely join two parts.
- Cylinder head screws with internal hex drives are often used for backing panels or hinges. Their length varies significantly.
Confusing the two can cause problems, as the bolts often do not grip deeply enough if the screw is too short. There are also differences in length and thread among the smaller particle board screws, which should not be interchanged.
It is worthwhile to carefully sort the screws beforehand by size and head type and to closely follow the instructions, especially for the connectors used on the carcass corners.
As an addition: IKEA BESTA units typically use cam lock fasteners (dowels with a removable head). These require a specific screw or bolt that is not interchangeable with standard screws.
- The thickness of the cam lock head is very important. If you accidentally use a screw with a thinner or shorter head, you won’t be able to properly tighten the connection, or the stability will be compromised.
Also, the small screws for backs or hinges should not be replaced with larger ones, as they can damage the material or not fit correctly. The instruction manual is helpful here, but double-checking with the parts provided saves a lot of frustration.
sarla schrieb:
The main distinction in the BESTA system screws is usually between the connector bolts (dowels with machine screw threads) and the cylinder head screws with internal hex drive.I agree, but it’s also important to consider that these screws differ not only mechanically but also in terms of load-bearing capacity and function.
Using the cylinder head screws for structural connections with incorrect torque or in the wrong locations can lead to instability later on. Do you have specific examples of screw types that are often confused? From my experience on various projects, the length of the screws tends to be more critical than the screw type itself.
Danial schrieb:
Do you have specific examples of the types of screws that are often confused?Thanks for the hint, Danial. I’ve particularly noticed that the included screws, which look like cylinder head screws but come in different lengths, are very similar.
So I’m wondering if, for example, the short cylinder head screws meant for the back panel can simply be swapped with the longer ones that hold the side panels together or not.
Also, there are the so-called connector bolts, which look very similar in shape to the longer screws but can be tightened using a separate part.
I definitely don’t want to risk the stability by using or mixing up the wrong screws. Is there a reliable way to distinguish these or to be cautious without having to measure all the time?
