ᐅ Which screws are suitable for particularly heavy-duty Billy shelves?
Created on: 19 Dec 2023 08:37
eliemeoHello everyone, I plan to install particularly heavy Billy shelves from IKEA at my home, each with a significantly higher load capacity than usual. My question is: which screws are best suited for mounting these heavy Billy shelves to ensure maximum stability and safety? I am especially interested in the combination of screw type, material thickness, and possibly suitable wall anchors, as I will be attaching the shelves to a drywall. I want to avoid using screws that are too thin or inappropriate, as the shelf could bend over time or even come loose. Does anyone have experience or recommendations on which screws—possibly combined with specific wall anchors—have proven reliable under these conditions? Thanks in advance!
For heavy-duty Billy shelves on drywall, you should use metal toggle anchors or hollow wall anchors. Screws with a diameter of at least 5mm (0.2 inches) and a length of 50 to 70mm (2 to 2.75 inches) are ideal. Make sure the screws are made of stainless steel or galvanized steel to prevent corrosion.
To answer your question precisely: For mounting particularly heavy Billy shelves on drywall, I recommend the following approach. First, it is important to use screws together with appropriate anchors designed for hollow walls, as standard screws alone do not provide sufficient load capacity.
- Screw type: Fully threaded screws with a diameter of at least 5 mm (0.2 inches). Lengths between 60 and 80 mm (2.4 and 3.1 inches) are optimal, depending on the anchor length.
- Anchor type: Metal hollow wall anchors or heavy-duty anchors (e.g., toggle bolts, molly bolts). These distribute the load over a wide area behind the drywall.
- Material: Stainless steel or galvanized screws prevent rust and increase durability.
This combination ensures safe load bearing and prevents material failure. Additionally, you should always position the shelves so that screws ideally engage with the underlying framework (e.g., wall studs) or the load is distributed over multiple anchors.
If the shelf will bear very heavy loads, reinforcing the wall with additional beams or panels can also be advisable.
Franck schrieb:
Screws with a diameter of at least 5 mm (0.2 inches) and a length between 50 and 70 mm (2 to 2.75 inches) are ideal.That’s already a good start, but I think you can take it a step further. If you’re going to install such a heavy Billy bookshelf, give it some extra care and reinforce the wall with high-quality metal toggle bolts. These fasteners open up behind the drywall and provide serious holding power.😉
And yes, 5 mm (0.2 inches) thick screws are a must, but sinking them a bit deeper won’t hurt—especially if you want to be on the safe side. It might not look the best, but stability comes first! 🙂 If you can screw directly into the studs, that’s the best option if you can locate them; otherwise, use special anchors like these toggle bolts. Good luck and stay strong during installation :-)
Lorukeo schrieb:
Screws with full threads and a diameter of at least 5 mm (0.2 inches). Lengths between 60 and 80 mm (2.4 and 3.1 inches) are idealI agree with this. To ensure the Billy shelves remain stable under heavy load, I recommend using stainless steel screws of grade A2 or A4. These are not only corrosion-resistant but also have higher tensile strength than standard galvanized screws.
It is also important to increase the number of fastening points and, if necessary, use special heavy-duty anchor plugs. For drywall, ordinary plastic anchors are not suitable for heavy shelves.
In short: good screws combined with appropriate heavy-duty anchors create a secure system. Additionally, attaching the shelves to the wall studs, if possible, is the best way to distribute the load on a structurally stable framework.
