ᐅ Which replacement parts are the easiest to swap out on BILLY shelves?
Created on: 5 May 2023 10:23
Kodydi
Kodydi
5 May 2023 10:23
Good morning everyone, I have a question that came up while maintaining my BILLY shelves: Which replacement parts for BILLY shelves are the easiest to change? I am especially interested in whether there are certain components that typically fail or get damaged more often, and if replacing them is manageable for someone with moderate DIY skills. Any special tips on tools or procedures would also be helpful. Thanks in advance!
lubla
5 May 2023 11:04
The simplest replacement parts are the shelves and the plastic anchors that hold them in place. Both can usually be replaced without special tools. A damaged shelf can often be easily removed and replaced, and anchors are easy to insert.
RETRAVIS
5 May 2023 14:17
There are basically three groups of BILLY shelves where replacement parts can be relatively easily changed: shelves including the plastic dowels, back panels made of hardboard, and back panel nails or small screws.
Replacing the shelves does not require disassembling the entire unit, which makes the work much easier. The back panels can also be removed and replaced fairly easily, provided you work carefully to avoid causing further damage. Usually, a screwdriver and a small hammer are enough to remove and reinsert the back panel nails.
For the brackets of the door frames (if present) or special connecting fittings, the situation is a bit more complicated. These are often attached to the carcass, and caution is needed to avoid compromising the stability.
faso31
6 May 2023 08:39
RETRAVIS schrieb:
Replacing the shelves does not require disassembling the entire shelving unit, which makes the task much easier.
I basically agree with this, but it’s important to remember that the shelves themselves are often not really considered wear parts – it’s usually the support clips or dowels underneath.
So I wonder: What about the durability of these plastic components with extended use? Are there any experiences regarding whether the plastic material becomes brittle over time and therefore more prone to breaking?
Also, are the back panels made of hardboard significantly at risk from moisture or other environmental factors? In that case, replacing them might not be so straightforward if the shelving unit is located in an unsuitable room.
mauka
6 May 2023 21:11
faso31 schrieb:
Aren’t the back panels made of cardboard also highly vulnerable to moisture or other environmental factors?
Absolutely, that’s true! I once had a BILLY shelf unit in my basement apartment – the back panel really turned out to be its Achilles’ heel. But don’t worry, replacement parts are easy to get and swap out; you mainly just need some patience and a steady hand.
RETRAVIS schrieb:
Usually, a screwdriver and a small hammer are enough to remove and reinsert the nails holding the back panel.
Exactly. And if you’re not aiming to drill like a pro, you won’t go wrong by working carefully to avoid tearing the cardboard. And hey, if you deal with the plastic anchors first, you’re usually halfway there. You could say: The rough but charming weak points of every BILLY shelf are quite manageable that way. 🙂
