ᐅ Which LED lighting is suitable for IKEA Besta shelving units and sideboards?
Created on: 2 Aug 2018 08:37
Mupau69
Mupau69
2 Aug 2018 08:37
Hello everyone, I am considering upgrading my IKEA Besta shelf unit or sideboard with LED lighting, but I have a few specific questions: Which LED lighting works best with Besta furniture in terms of color rendering, brightness, and easy installation? It is important to me that the LEDs not only enhance the look of the furniture but are also practical, for example with glass doors or open shelves. I am also thinking about which color temperature is ideal for living spaces – more warm white or neutral white? Are there any recommendations from the forum on products that work well with IKEA, what to watch out for during installation (e.g., wiring, power supplies), and whether it is better to use flexible LED strips or fixed light bars? I would appreciate any tips!
bijo54
2 Aug 2018 09:51
I recommend LED strips with 3000K, as they provide warm white light and create a cozy atmosphere. Flexible strips are best because you can easily cut them to size and attach them with 3M adhesive. It’s better to buy power supplies separately, as those from IKEA are often too weak.
fugolo
2 Aug 2018 10:14
Hello Mupau69, I’ll explain in more detail:
1. Color temperature: For living spaces, a range between 2700K and 3500K is usually recommended. Warm white creates a cozy atmosphere, while neutral white appears clearer and more modern. 3000K is a good middle ground.
2. Brightness: Pay attention to the lumen output. About 300–500 lumens per meter (3.3 feet) of LED strip is suitable for indirect lighting.
3. Installation: Flexible LED strips are ideal for Besta shelving units, as they can be bent around corners. Many come with a self-adhesive backing, which makes installation easier.
4. Power supplies: Choose a stable power supply matched to the LED wattage. Multiple strips can be powered by a suitable single power supply.
5. Integration: For glass doors, it can be practical to place the LEDs inside, along the top panel, to achieve indirect lighting. Open shelves benefit from spotlights or strips mounted under the shelves.
Summary: Flexible strips with about 3000K color temperature, adequate lumen output, a correct power supply, and adhesive backing provide a simple and effective solution for Besta furniture.
Joe52
2 Aug 2018 10:47
fugolo schrieb:
Flexible strips with about 3000K, good lumen output, proper power supply, adhesive backing.
Thanks for the summary! I spent a long time experimenting patiently myself and can confirm that installation is actually easier if you place the LED strips first before doing all the wiring. A small cable management clip helped me avoid tangled cables at Besta. It can feel overwhelming at first, but with a bit of planning, it works really well.
nofomu
2 Aug 2018 11:20
If you don’t want to do any soldering, you should look for LED strips with plug connectors. They are affordable and quick to install. A dimmer is also recommended if you want adjustable lighting.
REPITAR
2 Aug 2018 13:05
As a supplement:
- Pay attention to the IP rating of LED strips. Simple indoor strips are sufficient for enclosed shelves, but for open or more humid areas, it is better to choose protected ones.
- The color rendering index (CRI) should ideally be above 80 to ensure that colors on the furniture appear natural.
- Prefer spots instead of strips? Small LED spotlights are an alternative, depending on how your Besta unit is configured.
Common mistakes I often see: power supplies that are too weak, causing flickering or dimming of the LEDs. Also, incorrectly mounted strips (dirt on the adhesive surface) lose adhesion quickly.
