ᐅ Which Ikea PLATSA units are especially suitable for use as TV furniture?
Created on: 7 Jan 2022 14:37
daben
daben
7 Jan 2022 14:37
I am currently planning to rearrange my living room furniture and am very interested in the Ikea Platsa series because it is so flexible and modular. However, I am unsure which of the PLATSA units are best suited as TV furniture. Especially important to me are storage space for media devices and cable management, a sturdy construction to support a TV up to about 60 inches, and an attractive design that does not look too bulky.
Does anyone have experience or recommendations on which PLATSA modules or combinations work particularly well to create a functional and visually pleasing TV unit? I would also appreciate tips regarding the different depths and the choice between doors or open compartments. Thanks in advance!
raulso
7 Jan 2022 15:42
daben schrieb:
Does anyone have experience or recommendations on which PLATSA modules or combinations work best for creating a functional and attractive TV unit?
Hi, I used a combination of PLATSA cabinets with doors at home, which I use underneath for storing consoles and DVDs – it looks tidy and hides cable clutter well. The range of module widths is really great; I have two 60cm (24 inches) wide base cabinets with doors that serve as a perfect foundation. On top of those, I placed open shelves to prevent the TV boxes from overheating.
I wouldn’t choose too much depth; 35cm (14 inches) is usually enough so the furniture doesn’t appear too bulky. And of course, stability is important—make sure to screw everything firmly together, which is easy with PLATSA’s solid construction.
A small tip: use the back panel with openings or cut your own to allow enough cable passage. For the look, white fronts are timeless, but I’ve also experimented with colored doors, which adds a nice touch of personality to the room. 😉
Palenar
8 Jan 2022 09:11
daben schrieb:
Does anyone have experience or recommendations on which PLATSA modules or combinations work best to create a functional and aesthetically pleasing TV unit?
To address your requirements for a PLATSA TV unit in detail, you should consider the following points:
- Module size and depth: PLATSA offers frames with depths of 35 cm (14 inches) and 60 cm (24 inches). For TV units, the larger depth (60 cm) is often useful if you need space for receivers, gaming consoles, and larger speakers. The smaller depth (35 cm) is better for limited space and creates a slimmer profile.
- Combination of closed and open elements: For devices that generate heat, I recommend using open compartments or at least partially open doors (e.g., with perforated fronts or mesh) to ensure proper air circulation.
- Cable management: You can cut holes in PLATSA back panels with a jigsaw if none are provided. There is also optional cable management hardware available to integrate. Floor supports are also helpful to slightly raise the unit and neatly route cables underneath.
- Stability: Screws and fasteners are essential. PLATSA is modular, but with the right connectors, the unit becomes very stable, even for TVs up to around 60 inches.
- Design: For a harmonious overall look, either a uniform color scheme with white fronts works well, or mixing open elements and closed doors creates an attractive asymmetrical style.
It is also important to know whether you plan to place the TV directly on the unit or prefer a wall mount. Plus, room size and seating height influence the ideal furniture selection.
If you like, please provide some measurements of the TV and room so that more targeted recommendations can be made.
nonpra
8 Jan 2022 17:54
raulso schrieb:
I wouldn’t choose too much depth; 35 cm (14 inches) is usually enough so the furniture doesn’t look too bulky.
A depth of 35 cm (14 inches) is often tight for TVs up to 60 inches, especially with larger devices or if additional equipment needs to be stored.
Palenar schrieb:
PLATSA offers frames in depths of 35 cm (14 inches) and 60 cm (24 inches).
A depth of 60 cm (24 inches) is usually the safer choice if you need ample storage for receivers, sound systems, and the like. If it’s just a TV stand with minimal accessories, 35 cm (14 inches) will be sufficient.
draleo
9 Jan 2022 11:03
daben schrieb:
Does anyone have experience or recommendations on which PLATSA modules or combinations work best for creating a functional and aesthetically pleasing TV unit?
After reviewing the PLATSA products, I can clarify the following:
- The optimal depth for accommodating modern flat-screen TVs and additional devices is 60 cm (24 inches). This ensures enough space for cables and ventilated equipment.
- Modules with doors are recommended if storage space is needed and a clean appearance is preferred. Windowed or lattice doors are available only to a limited extent.
- Open shelves are suitable for devices that require air circulation. With PLATSA, open compartments can be created by omitting doors.
- Efficient cable management can be achieved by removing or modifying the back panels. The design allows for easy customization.
- For maximum stability, additional connections using the supplied connectors or optional screws are advisable.
- White fronts are the most versatile in terms of color; combined with wood or decorative elements, they create a modern look.
In summary, I recommend:
- Using 60 cm (24 inches) deep frames as a base
- Combining closed and open compartments
- Planning individual cable passages
If there are specific requirements, please add them.
