ᐅ Which DIY modifications are suitable for Ikea Hemnes furniture?
Created on: 30 Nov 2021 18:37
fibla42
fibla42
30 Nov 2021 18:37
I am currently planning to customize my Ikea Hemnes furniture to make it more unique, using DIY modifications that fit well. My specific question is: What types of DIY modifications work particularly well for the Hemnes series, especially regarding adjustments like surface treatments, hardware changes, functional additions, or even structural alterations?
I would like to hear about your practical experiences and tips, especially concerning material compatibility and long-term durability. Are there common pitfalls or limitations to be aware of when modifying Hemnes furniture? Thanks in advance for your help!
toril
30 Nov 2021 20:41
One of the most common and proven DIY modifications for Ikea Hemnes furniture is sanding and refinishing the surfaces. The solid wood used in the Hemnes series is well suited for sanding and then applying a satin finish or oil to customize the piece.
Additionally, the handles can be easily swapped out for high-quality metal ones, which noticeably enhance the style. However, it is important to pay attention to matching screw hole distances, as Ikea uses standard dimensions.
Functional upgrades, such as installing LED lighting in glass cabinet doors or using internal drawers, are also easily achievable. For more extensive structural modifications, caution is advised because the furniture combines solid wood with MDF elements—excessive cutting or drilling can compromise stability.
nera59
1 Dec 2021 09:22
toril schrieb:
The solid wood of the Hemnes series is well suited for sanding and applying a matte satin varnish or oil afterwards
Additionally, I recommend gradually using finer grit sandpapers during sanding to achieve a smooth surface without scratches. Before varnishing, the wood grain should be thoroughly cleaned and degreased to improve adhesion.
It is also worthwhile to work precisely when replacing fittings and to fill old holes with wood filler if necessary before drilling new ones. This helps prevent unwanted weak points and visual imperfections.
I have also had good experience using tetrachloroethane as a primer when Hemnes furniture is placed in damp rooms—this helps the paint last longer. For beginners, installing additional shelves that can be retrofitted with simple drillings is also recommended. This significantly increases functionality.
Devin
1 Dec 2021 14:03
I have fitted Hemnes dressers with different handles and new metal legs – this is practical and gives a much more modern look. For additional storage, I use small inner drawers that can be easily placed inside.
gadalu
2 Dec 2021 11:55
nera59 schrieb:
I have also had good experiences using tetrachloroethanol as a primer when Hemnes furniture is placed in damp rooms
This is an important tip. Especially for Hemnes furniture, which is often used in bedrooms or living rooms, proper surface preparation is crucial. Those who want to work with paint should use a high-quality primer and finish coat, as the wood surface is porous and absorbs moisture.
Another common modification is converting the pieces into TV furniture. In this case, it is helpful to cut out the back panels for cable management or ventilation. Pay attention to stability—additional reinforcements are recommended.
Structurally, Hemnes can be expanded to some extent, but using custom-made connectors or furniture legs to raise the piece is advisable if you want to adjust the design without risking its load-bearing capacity.
