ᐅ Which clamping method is recommended for Ikea Metod wall cabinets?
Created on: 9 Jun 2017 08:12
Joeyno
Hello everyone, I am currently planning the installation of Ikea Metod wall cabinets in my new kitchen. I am particularly interested in the question: which clamping method is practical and safe for these wall cabinets to ensure both load-bearing capacity and the possibility of later adjustments? There are different ways to attach the cabinets to the wall – for example, direct screwing into the wall, using clamping brackets, or special mounting rails.
I want to focus especially on how the clamping technique affects stability and future handling, as I have some concerns about whether the cabinets can be easily removed later without causing damage. Additionally, I am curious if the technique varies depending on the type of wall (e.g., concrete, drywall/plasterboard, timber studs) and which clamping methods work best in practice.
I look forward to your tips, experiences, and recommendations. Thanks in advance!
keosau9
9 Jun 2017 11:05
Specifically: Screw the rail to the wall, hang the cabinet, and tighten the clamping screws. This is the secure combination. Without screws in the wall, it will be unstable.
fiman
9 Jun 2017 11:23
I recommend using expansion anchors for drywall. Clamps for securing are okay, but the main load should always be supported by screws.
Joeyno
9 Jun 2017 12:02
deoke schrieb:
I consider a clamping method without fixed screwing to be questionable since the load mainly acts in tension.
That sounds reasonable. However, I wonder how significant the difference in load capacity is between direct screwing and clamping rails. Are there any practical experiences indicating whether clamps are sufficient for medium-sized cabinets (about 30kg (66 lbs) per cabinet), or if direct screwing is absolutely necessary?
I also still have questions about how this varies with different wall types. Perhaps someone has direct experience with drywall (gypsum board) walls and these clamping methods?
luAlbert1
9 Jun 2017 12:30
Joeyno schrieb:
Maybe someone has specific experience with drywall and these clamping techniques?
In my opinion, clamping strips for drywall are a bit of a gamble. Heavy-duty anchors or even mounting a wooden batten horizontally behind the drywall sheets and then screwing the cabinets to that are much better. That definitely holds far more than any clamp. The heavier the load, the more secure the fixing should be!
leomo
9 Jun 2017 13:14
luAlbert1 schrieb:
Heavy-duty anchors or even installing a wooden batten horizontally on the wall behind the drywall panels are better
That also sounds like a clever trick! A wooden batten for reinforcement plus a rail – then everything holds twice as well. 😎 Great tip for people who don’t have solid masonry!
deoke
10 Jun 2017 08:18
To clarify the load capacity: If you are talking about approximately 30 kg (66 lbs) per cabinet, the mounting must be able to support several times that weight to ensure a sufficient safety margin. The hanging rails used by Ikea are not just simple clips; they are attached with strong screws and wall plugs.
The clips themselves, which secure the cabinets to the rail, hardly bear any load; they mainly serve to lock the cabinets in place so they don’t slip or accidentally come loose.
If you are mounting on gypsum board (drywall), standard wall plugs are not recommended. Professional metal anchors or hollow wall anchors are essential, or alternatively, additional reinforcements like wooden battens or metal profiles behind the wall.
It is also worth considering how often you plan to take the cabinets off and put them back up – if this will happen frequently, clipping systems with a secure hold are very useful; otherwise, screwed mounting is preferable.
