ᐅ What care products are recommended for Malm furniture?
Created on: 8 May 2020 11:23
SARPAR63
SARPAR63
8 May 2020 11:23
I recently bought some furniture from the Malm series – mainly dressers and nightstands from Ikea. Since these pieces are typically made of particleboard with a foil or lacquer finish, I would like to know: which care products are best suited for cleaning, maintaining, and protecting Malm furniture surfaces in the long term without damaging the foil or veneer?
I’m specifically looking for recommendations for mild but effective care products available on the market, as well as tips on the proper cleaning and maintenance techniques. Many manufacturers only provide general advice, and I want to make sure I don’t accidentally harm the furniture.
Has anyone had experience with specially suitable cleaners or care products for Malm furniture? Thanks for your tips!
Espen
8 May 2020 11:57
For Malm furniture, I simply recommend pH-neutral cleaning agents. A damp microfiber cloth is usually sufficient.
Do not use glass cleaner or abrasive cleaners, as the foil will quickly be damaged.
KIN42
8 May 2020 13:14
are definitely the right approach.
Additionally, I recommend using special furniture care products containing silicones for occasional maintenance. These protect the foil surface from drying out and scratches without leaving any residue.
Make sure to apply care products to small sections and always work gently with a soft cloth.
tra_nina
8 May 2020 15:42
For reference: Malm furniture is usually covered with a melamine foil imitation, which is quite durable.
I advise against using oil or wax treatments, as these can damage the surface or leave a permanent dull finish. Unlike solid wood, this type of furniture does not require additional oiling.
For cleaning, mild detergents are sufficient, such as all-purpose cleaners without aggressive solvents, ideally those specifically designed for laminate or similar surfaces.
GAGRAHAM
9 May 2020 10:01
Hello everyone!
I find this topic really interesting and have already experimented a lot myself! For Malm furniture, I often use a special furniture care spray with a matte finish. This creates a non-glossy surface while providing excellent protection!
My tip: Simply spray it on after cleaning, rub it in with a soft cloth, and enjoy the results. The furniture immediately feels well cared for, and minor scratches become hardly noticeable 🙂
It’s really enjoyable when the furniture looks so neat!
Henry
9 May 2020 16:37
GAGRAHAM schrieb:
I often use a special furniture care spray with a matte finish for Malm
Thanks for the tip, that sounds interesting! I’m currently wondering about the best way to treat minor scratches on Malm furniture as well.
Does anyone have experience with repair kits or something similar? I want to avoid the spots or scratches becoming permanent blemishes. Your advice would be greatly appreciated!
