ᐅ Which Billy shelves have the highest load capacity?
Created on: 14 Aug 2018 19:23
Lyanle
Lyanle
14 Aug 2018 19:23
I am planning to use several Billy bookcases from IKEA to create a sturdy storage solution for heavy books and binders. My question is: which Billy bookcases have the highest load capacity?
I understand that the load capacity can vary depending on the width, number, and material of the shelves, but I would like to know if there are specific models or versions designed explicitly for higher loads.
I am also interested in any tips on how to better distribute or increase the load capacity without having to switch to a different shelving series.
I look forward to your experiences and recommendations!
devon9
14 Aug 2018 22:46
Hello Lyanle,
First of all, it’s good that you’re specifically asking about the maximum load capacity of the Billy shelves, as there are some important differences to consider.
The standard Billy shelves (80 cm (31.5 inches) wide) can hold about 30 kg (66 lbs) per shelf, assuming the load is evenly distributed. The 40 cm (15.7 inches) wide versions often have a slightly higher load capacity per shelf, around 35 kg (77 lbs), because the shorter shelf board sags less.
Important:
- The height of the shelf affects its stability. Very tall shelves (e.g., 202 cm (79.5 inches)) should always be secured to the wall to avoid exceeding the load limits.
- It is possible to add extra shelves, for example, every 20 cm (7.9 inches), but you should make sure the shelves are not too thin and don’t bend under load.
Tips to increase load capacity:
1. Use wall mounting: This prevents tipping and allows for slightly higher point loads.
2. Provide additional support for shelves with shelf edging, for example, by attaching small wooden strips to the back panel.
3. Avoid loading the shelves all the way to the edges, as the greatest stress is in the middle.
If you really want maximum load capacity, there are also specially reinforced Billy versions with additional metal braces on the back panel or thicker shelves – these models are not routinely available at every IKEA store.
If you like, I can also explain the material differences or suggest alternative solutions.
Best regards!
mintra
15 Aug 2018 07:12
devon9 schrieb:
The standard Billy shelves (80 cm (31.5 inches) wide) support approximately 30 kg (66 lbs) per shelf when the load is evenly distributed.
That is correct. Additionally, the maximum load capacity also depends on the loaded depth. For the standard Billy shelves (about 28 cm (11 inches) deep), 30 kg (66 lbs) is a general guideline, which can be lower depending on specific loading conditions.
For particularly heavy loads, the "Billy/Brimnes" model with metal reinforcements is recommended – these can support up to 40 kg (88 lbs) per shelf, as the added reinforcement significantly reduces shelf bending.
Dividing the shelving unit into several sections (i.e., several narrower shelves placed side by side instead of one wide shelf) also improves overall stability.
It is important to regularly inspect the shelves, as very heavy weights over time can cause material fatigue.
In short: the highest load capacity for Billy shelves is achieved with the narrower, extra-reinforced models combined with wall mounting.
gipifa
15 Aug 2018 11:57
Hey Lyanle and everyone else!
I have to say, this topic is really interesting, especially if you have as many stacks of books as I do 😉
devon9 schrieb:
The 40 cm (16 inch) wide versions often have a slightly higher load capacity per shelf
I can definitely confirm that! I have two 40 cm (16 inch) wide Billy shelves that are surprisingly sturdy. You really notice the extra stability, especially when you put a lot of thick encyclopedias or heavy binders on them.
What I highly recommend is occasionally treating the shelves with wood varnish to protect against moisture damage – especially if you want them to last.
And last but not least: always secure the shelf to the wall!!! Safety comes first, and it also reduces sagging.
Good luck with your project – be prepared to find many reasons to buy more Billy shelves very quickly :-)
libar49
16 Aug 2018 09:38
mintra schrieb:
For especially heavy loads, the "Billy/Brimnes" model with metal braces is recommended
Interesting, but I doubt that the metal braces actually provide significantly more load capacity. In my experience, this is mainly a marketing feature that suggests more safety than it truly offers.
What none of the previous replies have considered:
Shelving like Billy is designed for typical living room use. If you want to store heavy boxes or tons of books, no flat-pack furniture shelving will help here. The cross-section is too small, and the material too thin.
My advice: if load capacity is your top priority, I would opt for a professional heavy-duty shelving system. Cheap shelves with metal braces are always a compromise between price and stability and are not suitable for the heaviest loads.
Of course, you could argue, “I don’t need 200kg (440 lbs) per shelf,” but it’s better to be safe from the start than to end up with a creaking Billy shelf full of books that’s about to collapse any moment.
