ᐅ What to do if the doors of Ikea BRIMNES do not close properly?
Created on: 18 Oct 2024 08:37
lenpo62
I recently bought an Ikea Brimnes wardrobe set and am generally happy with the design and functionality, but the doors on mine don’t close properly. They always remain slightly ajar or close with a noticeable gap to the frame, allowing dust to collect inside.
I have already checked if the hinges are correctly installed and if the doors are warped, but I couldn’t find any obvious issues. Are there any specific adjustment options for BRIMNES that I might have missed?
Or do you have practical tips on how to adjust the doors so they close flush and quietly?
I am using the wardrobe in a rather humid room – could that be a factor?
Thanks in advance for your advice!
KAULIS
19 Oct 2024 08:02
Summary and additional information regarding Ikea Brimnes doors that do not close properly:
- Check the cabinet’s position using a spirit level to rule out warping.
- Adjust the hinges:
- Horizontal alignment allows for a flush closing.
- Vertical adjustment prevents doors from sagging or sticking.
- Depth adjustment affects the seal against the cabinet frame.
- Removing the doors for easier adjustment is recommended.
- Moisture can cause warping, so sensitive furniture should be kept in dry rooms.
- Optionally, soft felt strips can be attached to the inside of the doors to provide cushioning and dampening.
- Tighten screws with moderate force to avoid damaging the material.
A well-aligned BRIMNES wardrobe typically does not require any additional technical modifications. If all measures fail, it is advisable to file a complaint or contact Ikea support for replacement parts.
These tips are based on technical specifications and user experience reports.
