ᐅ What tips are there for assembling Billy bookcases in older homes?
Created on: 4 Jul 2018 09:37
teodra53
teodra53
4 Jul 2018 09:37
I am planning to assemble several IKEA Billy bookcases in my older apartment, but I am unsure about some of the structural challenges involved. Especially because of the often uneven walls and old plaster layers, I’m wondering what preparations or tricks you would recommend to securely and evenly install the shelves.
I am also concerned about attaching them to the walls, as the walls are sometimes quite fragile, and I’m afraid of damaging them when screwing in the fasteners. Are there specific anchors or methods that work particularly well for older buildings?
Furthermore, I’m interested in any experience you might have with leveling measures if the shelves don’t stand completely straight—for example, using shims or something similar.
What tips or proven methods can you share for assembling and wall-mounting Billy bookcases in an older building with very uneven walls? Thanks in advance!
botibo
4 Jul 2018 11:22
Hello teodra53,
I know the problem with old walls all too well! 😊 My first tip: Always pre-drill with a small drill bit and use high-quality anchors. For porous masonry, so-called nylon expansion anchors often work better as they adapt more effectively.
teodra53 schrieb:
because of the often uneven walls and old plaster layers, I wonder what preparations or tricks you would recommend
For uneven spots: wedge washers or wooden shims behind the back of the shelf to secure it firmly. For highly warped walls, you can also use thin plastic spatulas underneath – that provides surprisingly good stability.
And don’t forget, when installing, it’s worth using a spirit level and spacers to ensure it looks great too! 😉 Thumbs up for DIY in older buildings!
Annedeo
5 Jul 2018 08:16
Hello teodra53,
I would like to add a few important basics. Especially with older walls, the plaster can be unstable, so it is advisable to check the fixing points before installation – gently tap or pull on the wall to identify any loose plaster.
teodra53 schrieb:
because the walls are sometimes very fragile, and I’m afraid of damaging them when screwing in the screws
In such cases, I recommend cavity anchors or special renovation anchors that put less stress on the wall. If possible, drill directly into the load-bearing masonry, as this usually offers better support.
Regarding leveling measures, I can confirm that wooden wedges or homemade cardboard strips help to align shelves on uneven floors or against uneven walls. Always assemble slowly and check carefully to avoid unpleasant surprises. Good luck!
BOSUDA
5 Jul 2018 10:42
Pre-drill holes, use impact screws or frame anchors.
Align the shelf with spacer blocks.
Do not use plaster as a support; screw directly into the masonry.
This is how I do it in old buildings.
Fredlo
6 Jul 2018 19:03
Assembling the Billy shelf in an older building? Super exciting 🙂! Here are a few encouraging tips:
First: Always use a spirit level, really important. Especially when the walls are uneven, it makes for a great result!
botibo schrieb:
For uneven spots: wedge washers or wooden shims behind the back of the shelf, then it stands rock solid.
Exactly that! And if the wall is too fragile, better to hang it from the ceiling or combine with freestanding shelves – that way everything stays secure.
The assembly will be a success, and if not, just reach out here, I’m happy to help with more tips! I love when old apartments keep their charm with modern furniture while still being practical! 🙂
