ᐅ What stability issues commonly occur with Ikea PLATSA furniture?
Created on: 13 Jan 2016 08:17
DITARUHello everyone, I have a question about the stability issues that often occur with Ikea Platsa furniture. I have noticed that despite following the assembly instructions carefully and assembling everything correctly, some users report instability or weaknesses in the construction, especially with tall or combined modules. I am particularly interested in the typical weak points, for example, whether the problems are more related to the fastenings, screws, materials, or the design itself. Are there specific aspects of the system that should be paid close attention to in order to prevent wobbling or even hazardous tipping movements? And are these problems more pronounced with certain versions? Thank you very much for your assessments and experiences!
In my experience, the main issue with PLATSA systems often lies in the connection between the individual modules and their attachment to the wall. The screws and the materials themselves are adequate, but without very careful and, above all, correct wall mounting, larger or taller assemblies quickly become unstable. In particular, the connectors between the individual cabinets are not designed to withstand significant horizontal loads. This often leads to misaligned angles or slight wobbling, which becomes more noticeable during everyday use. Another point is the frequently missing or insufficient use of the included wall brackets, which are essential for the necessary stability.
I find this topic really fascinating! 😊 Especially with PLATSA, it’s crucial to follow every single assembly step carefully. I’ve seen firsthand how a small oversight with the screw connections between the modules can make the entire unit wobbly. However, if you use the supplied angle brackets to secure it to the wall and horizontally between the modules, the system becomes very stable! For anyone wanting to be on the safe side: make sure to properly fix it to the wall; otherwise, it can indeed lead to unstable situations!
Oh yes, I can only confirm that! I was initially skeptical, but after careful assembly, my PLATSA combination is really solid! 😊 You just need to pay attention to two things: - Make sure to secure the wall brackets deeply into the wall (use anchors!) - Don’t just snap the modules together; screw them so they cannot move against each other. Taking the time to do this properly is definitely worth it, otherwise it might tip over. So don’t be afraid of the assembly, just work carefully!
olivernu schrieb:
From my experience, the main issue with the PLATSA systems often lies in the connection between the individual modules themselves and to the wall. I can only partly agree with that. I think Ikea is often given too much credit here. In my opinion, the design of the PLATSA system focuses more on visual flexibility than on maximum stability. That means: if you love the design, you shouldn’t expect miracles in terms of sturdiness. The system mainly uses particleboard and simple screw connections, suitable for light to moderate household use—but not for heavy loads or children’s rooms where there’s a lot of rough play. There is a risk of tipping with taller modules or uneven loading. Sometimes, this can even be dangerous.
nedagla schrieb:
But if you use the included angle brackets for attaching to the wall and horizontally between the modules, the system is very stable! It would be nice if that were always enough. There are also cases where the supplied screws don’t work with the wall (e.g., drywall without appropriate anchors), and then stability is compromised. So: stability strongly depends on factors Ikea cannot control. This also means that self-assembly, wall type, and usage are important—but in the end, I would never call the PLATSA system the most robust solution.
