ᐅ What common issues are encountered when assembling Ikea HEMNES furniture?
Created on: 5 Aug 2024 09:12
dudleygau
dudleygau
5 Aug 2024 09:12
Hello everyone, I would like to start a discussion on the topic “What common problems occur when assembling the Ikea Hemnes series?” At first glance, the HEMNES series seems quite straightforward, but I often encounter some difficulties during assembly that take up extra time and lead me to double-check certain steps. I am especially interested in experiences regarding the following points: - Does the instruction manual perfectly match the supplied parts? - Are there typical pitfalls when assembling the cabinet doors or drawers? - How is the quality and accuracy of the wooden parts, for example, do holes or dowels not align precisely? - What additional tools are useful to have on hand? I have already tried working with a cordless drill and a spirit level, but I would appreciate your insights and tips to optimize the assembly process and, if possible, avoid common mistakes in advance. Many thanks in advance to everyone who shares their experiences!
ju_ren
5 Aug 2024 10:23
It is very common for wooden parts to be warped sometimes. Check the components before assembly and sand any edges that can be sanded if necessary. For the cabinet doors: make sure to install the hinges correctly, as this often causes problems. It is best to carefully review the instructions again before installation.
Davidleo
5 Aug 2024 12:01
Hey, I love the HEMNES series! 😍 But yes, assembly can be tricky sometimes, especially getting the drawers to fit perfectly 😉. My tips: Always tighten all screws just by hand at first and do the final adjustment at the end! And definitely get a cordless screwdriver with a continuously adjustable torque setting – it makes many things easier! You can do it, just take it step by step 👍!
benon
5 Aug 2024 15:47
Hello dudleygau, this is a very good and specific question about assembling the HEMNES furniture. I often find that users struggle particularly with fitting the back panel, as it can sometimes be slightly warped when delivered or may not align perfectly with the holes in the side panels. The instructions can also seem a bit unclear in some places, so careful consideration and checking of each step is often necessary. The drawers often don’t slide smoothly if the runners are not adjusted precisely. Therefore, my advice: - Use a cordless screwdriver set to a low torque setting or tighten screws carefully by hand - Use a spirit level or a small square to align the vertical surfaces accurately - Always check the correct order when assembling the drawer slides - Make sure to measure all wooden parts for dimensional accuracy before assembly, as even small deviations can cause problems I hope this helps make the assembly process easier!
ju_ren
6 Aug 2024 07:18
benon schrieb:
The drawers often don’t slide smoothly for us if the drawer runners are not precisely adjusted.
Exactly. Simply installing them straight and closing with gentle pressure usually helps.
Jensson
6 Aug 2024 13:34
Hello everyone, I would like to share a brief guide that I put together for assembling the HEMNES furniture. My experience has shown that the following points are particularly critical: 1. Check the delivered parts before starting: Compare the quantity and type of screws with the packing list, as in some cases screws are incorrect or missing. 2. Tool selection: Besides a cordless screwdriver, I recommend a Phillips head and a flathead screwdriver, a small wooden mallet for dowels, and a spirit level. 3. Assemble the back panels carefully: These provide stability. If installed upside down or at an angle, the furniture will be unstable. 4. Adjusting the doors: With HEMNES, you often need to modify both hinges; the adjustable screws on the inside are important for this. 5. Handling small parts: Some need to be inserted gently. Dowels must not be hammered in forcefully to avoid splitting. 6. Follow the sequence: It is important to secure the side panels and base first before installing doors or drawers. This prevents parts from colliding. 7. Workspace and lighting: Good preparation and sufficient lighting make a big difference. This helps you read the instructions better and avoid mistakes. In summary: The HEMNES series is well designed, but with some patience and the right tools, assembly goes much more smoothly. It’s also practical to assemble with an experienced person so that any questions can be clarified.
