ᐅ What potential mistakes should be avoided when assembling Malm furniture?
Created on: 7 Nov 2020 08:43
haukar
Hello everyone, I am currently working on assembling an IKEA Malm wardrobe and would like to ask specifically about common mistakes that often occur during the process.
I am especially interested in which potential errors to watch out for when assembling the Malm, meaning which pitfalls or tricky parts are best to know about in order to save time and avoid frustration.
Specifically: Are there components that are easily confused with others? How critical are the positions of screws or dowels? And are there common mistakes that are easy to overlook but can later cause significant problems with stability or functionality?
I look forward to your experiences, particularly practical tips and advice on errors that even professionals sometimes make. Thank you in advance!
Elodie
8 Nov 2020 09:13
Hi everyone,
I’d like to add that small parts like plastic stoppers or glides are often forgotten or installed incorrectly in the rush. This can cause the cabinet to squeak during use or damage the floor.
Surela schrieb:
Installing the drawer slides requires precision, especially with Malm, as incorrect alignment leads to sticking drawers and uneven gaps.
I completely agree – I always take my time to align the slides perfectly. A quick check with a small spirit level or ruler beforehand can save a lot of trouble later.
And it may sound obvious, but: check multiple times during assembly that screws are neither too tight nor too loose. This avoids the extremes that could damage the furniture. 🙂
Hope this helps!
Saramar
8 Nov 2020 11:26
haukar schrieb:
How critical are the screw or dowel positions?
Very critical. Securing the side panels with screws is essential for stability. If you’re not precise with the angle and the screw shifts, the wood can split. I’ve also noticed that dowel holes are often quite tight – using the wrong insertion technique can result in an unstable joint.
My advice: pre-drill screw holes whenever possible, insert dowels fully and straight, and leave some play when screwing so the wood can adjust slightly. Then tighten the screws last. This way, you get a smooth and stable construction.
barda6
8 Nov 2020 11:41
Just a quick note:
1. Is the back panel installed crooked? This is a common mistake that can make the entire cabinet unstable.
2. Missing or incorrectly inserted screws (e.g., the small cross connectors) are often overlooked.
Simple tip: After assembling each major section, double-check that all screws are in place and tightened.
GIPAPO
8 Nov 2020 13:33
Errors during assembly of the Malm can also include:
- Dowels glued incorrectly or not glued at all – this results in no stability.
- Drawer slides not exactly parallel – causing the drawer to stick.
- Screws over-tightened – which loosens the connection.
It is best to sort and check all parts before each assembly step.
