ᐅ What common mistakes are made when assembling IKEA Hemnes furniture?
Created on: 20 May 2021 18:27
KelutiHello everyone, I am currently working on assembling IKEA Hemnes furniture, especially dressers and beds, and have often heard about mistakes that occur during assembly. I am particularly interested in the most common errors encountered when putting together these pieces. I am not only referring to simple assembly steps but also to issues caused by misunderstandings of the instructions, incorrect sequencing, handling of the supplied fittings, or using inadequate tools. Who has experience with this, what are the most frequent pitfalls when assembling Hemnes furniture, and how can they best be avoided? Thanks in advance for your detailed feedback!
Hey Keluti, great that you’re bringing up this topic here! I’ve assembled several Hemnes cabinets and from my experience, two issues often cause problems: First, mixing up the wooden parts because they mostly look very similar, especially the side panels and shelves. This often means you have to rearrange things right from the first step. 😅 Second, screws and dowels are sometimes not fully or correctly inserted, which can compromise stability later on. An important tip from me: always study the instructions carefully and thoroughly check all parts before you start screwing anything together. Also, patience really pays off here! So, don’t rush and if you’re unsure, double-check everything again. Good luck and don’t lose the fun of building! 🙂
Hello Keluti, I would like to take a more technical and systematic look at the common mistakes made when assembling Hemnes furniture. Based on my experience and numerous assembly reports, I would summarize the most frequent sources of errors as follows:
- Confusing wooden parts: The components are usually only distinguishable by small markings or numbers on the backside. If this is not done carefully, the next step naturally will not fit or the structure will become asymmetrical.
- Incorrect handling of fittings: The carcasses often consist of a mix of different screws, dowels, and metal brackets. One common mistake is driving screws too deep or too shallow, which affects stability. In addition, incorrectly installed metal brackets can cause strain.
- Assembly sequence: Especially with larger furniture like Hemnes dressers, following the exact order of the instructions is crucial. Sometimes, side panels are mounted too early before the shelves are fixed – this makes later adjustments difficult or can even cause damage.
- Avoiding the use of aids: Using cordless drills can be tempting, but extreme caution is needed since excessive torque can damage pre-drilled holes. Manual skill is required here.
- Missing stabilization from back panels: Sometimes the back panel is attached last, but in Hemnes furniture, the back panels are load-bearing elements. If they are mounted late or poorly, the piece can become unstable or warp.
Regarding your question on how to avoid this: I recommend a thorough visual inspection of all parts before starting, sorting and marking them, then assembling step by step according to the instructions – no shortcuts. One additional tip: download the instructions online in high resolution; sometimes they are easier to read there.
What exactly are you assembling? Are there specific areas or steps causing you trouble right now?
kibutar schrieb:
Incorrect handling of fittings: The carcasses often consist of a mix of different screws, dowels, and metal brackets. One common mistake is inserting the screws too deep or too shallow, which compromises stability.I would like to support and clarify this observation. A frequent mistake with Hemnes furniture is overtightening or undertightening the screws, which reduces the load-bearing capacity of the joints. It is important to follow the recommended tightening torque exactly, even if it is not explicitly stated in the instructions. Additionally, problems often arise because the pre-drilled holes are not always perfectly aligned. Therefore, I recommend assembling the parts loosely first and carefully tightening all screws before fully securing the connections.
It is also important to ensure the furniture is assembled on a level surface. An uneven assembly quickly leads to distortion and increases the likelihood of mounting stresses and fit issues.
Another point is to carefully inspect the back panels before installation. These are often made of thinner material and are not always positioned correctly, which causes bending or warping of the furniture.
In summary, the most common errors result from imprecise quality checks and rushing during assembly. Patience and a careful approach are the best prevention.
