ᐅ What is the load capacity of the IKEA Hemnes shelves?
Created on: 25 May 2024 18:37
guhau
guhau
25 May 2024 18:37
I am planning to get one of the IKEA Hemnes shelving units but have some questions regarding the load capacity of the individual shelves. My specific question is: what is the actual load capacity of each shelf in the Hemnes units? Are there official specifications or practical experience indicating how much weight a shelf can support long-term without damaging the unit or compromising its stability? I am particularly interested in whether heavy books or other bulky items can be safely stored without the risk of the shelves sagging or the entire unit becoming unstable. I would appreciate any practical assessments or reliable manufacturer information, as I intend to use the shelving unit as storage for my extensive book collection.
meGreg
25 May 2024 19:52
guhau schrieb:
What is the actual load capacity of the individual shelves in the Hemnes units? Are there official specifications or practical experience on the maximum long-term weight each shelf can hold without damaging the unit or affecting its stability?
Good, precise question! The official specifications from IKEA usually list about 20-25 kg (44-55 lbs) per shelf for Hemnes units, but the values can vary depending on the model size and the number of shelves. In everyday use, the shelves can handle significantly more weight as long as the load is evenly distributed. For heavy stacks of books, it’s better to use multiple units or slightly vary the book width, since a fully loaded shelf behaves almost like a small weightlifter.
Proper installation is also important: follow the instructions exactly and add additional wall mounting, and the unit won’t wobble. So, if you take good care when assembling and maintaining the furniture, the Hemnes shelf can really carry a lot—almost like a brave Viking on four legs. 😉
KAULIS
26 May 2024 08:14
guhau schrieb:
What is the actual load capacity of the individual shelves in the Hemnes units? Are there official specifications or practical experience indicating how much weight each shelf can support long-term without damaging the unit or compromising stability?
The load capacity of the IKEA Hemnes shelves is usually stated as 20 kg per shelf (44 lbs) in the product description. This limit applies to evenly distributed loads. The shelves are made of solid wood or wood-based composite materials, which provide relatively good stability.
Additionally, installation combined with wall mounting is crucial for overall stability. Without securing the unit to the wall, its standing stability may be compromised, especially under heavier loads.
Practical experience shows that temporarily exceeding the load capacity is possible, but over time, shelf sagging and joint wear can occur. For heavy books, it is recommended to use multiple units or to choose models with metal supports or reinforced shelves.
Conclusion: According to manufacturer specifications and practical assessment, 20 kg per shelf (44 lbs) is the guideline for long-term use without impairments.
likuken
27 May 2024 13:48
meGreg schrieb:
The official specifications from IKEA usually state about 20-25 kg per shelf for Hemnes
I think that 20 kg per shelf is a rather conservative estimate. Considering that the shelves appear solid and are often made from solid wood or high-density engineered wood, they should be able to handle higher loads. In my opinion, the ratings tend to prioritize safety — which is understandable — but at the same time, this unnecessarily limits the usable capacity.
KAULIS schrieb:
For heavy books, it is recommended to use multiple shelves or switch to models with metal supports or reinforced shelf boards.
That is certainly the cautious and safe advice, but I know people who regularly store 30-40 kg per shelf and their shelves are still standing strong after years. Of course, if you want to keep the warranty, you should follow the manufacturer’s guidelines, but if you’re willing to check periodically for any signs of deformation, you can push the limits.
In any case, I would say the Hemnes unit is more robust than it is often rated. With proper installation and a few additional brackets here and there, it remains stable.
