ᐅ What is the load-bearing capacity of Ikea Pax shelving boards?
Created on: 2 Apr 2022 08:37
AmjadfloHello everyone,
I am planning to use an Ikea Pax shelving unit and intend to heavily load several shelves, mainly with books and some heavier decorative items. I have a question: what is the actual load capacity of the individual shelves in an Ikea Pax?
I am especially interested in the maximum load per shelf, considering they are typically made of particleboard, and how different types of loading (evenly distributed vs. point loads) affect this. It would also be helpful if anyone could share their personal experience in case the real values differ from the manufacturer’s specifications.
I want to avoid the shelves sagging or being damaged.
Thanks in advance for your input!
According to the official product information, the maximum load capacity of the Ikea Pax shelves is approximately 25 to 30 kilograms (55 to 66 pounds) of evenly distributed weight per shelf.
The construction type is important: the shelves are usually made of 16 mm (5/8 inch) thick particle board, which has some flexibility in the middle. Point loads, such as very heavy items placed on a small area, can significantly reduce the load-bearing capacity and cause sagging.
Additionally, it should be considered that the shelves are fastened with screws and wall plugs in the side panels, which also affect the overall stability.
Therefore, if you plan to store heavy stacks of books, the weight should be distributed as evenly as possible, and the maximum load capacity of 30 kg (66 pounds) per shelf should not be exceeded. Alternatively, you can install additional central supports or reinforcements to increase the load capacity.
Landontau2 Apr 2022 14:22Here is a brief guide to better assess and effectively use the load capacity of Ikea Pax shelves:
- Follow manufacturer’s specifications: The official load capacity is usually around 25–30 kg (55–66 lbs) per shelf.
- Even load distribution: To ensure the load-bearing capacity, heavy items should be spread out evenly across the shelf, not just placed in the center or one spot.
- Shelf thickness: Standard shelves are typically 16 mm (0.63 inches) thick; the thickness is crucial for how much the shelf will bend.
- Duration of use: Constant loading close to the maximum limit can weaken the shelf over time.
- Reinforcements: If heavier loads are planned, additional supports such as center braces or metal brackets can be added.
Also important: Check that the shelves are installed correctly, for example, that all retaining clips are properly engaged. Improper assembly often reduces load capacity more than expected.
One final tip: When storing books, it’s better to spread them across multiple shelves rather than stack them heavily on just a few, to better distribute the weight.
liskar schrieb:
According to the official product information, the maximum load capacity of the Ikea Pax shelves is about 25 to 30 kilograms (55 to 66 pounds) of evenly distributed weight per shelf.Exactly! I have several Pax shelves at home filled with books, and I always made sure to distribute the books evenly rather than stacking them all in the middle.
You can feel the shelves sag slightly if you overload them, but it only becomes critical as the load increases.
My advice: Always ensure an even distribution of heavy items; otherwise, you might hear a crack. And for extra safety, you can simply place a thin plywood sheet underneath to help distribute the weight more evenly. 😉
Amjadflo schrieb:
What is the load-bearing capacity of the individual shelves in Ikea Pax?The Pax shelves are designed for a maximum load of around 25 to 30 kg (55 to 66 lbs), as already mentioned. It is important that this load is distributed evenly across the entire shelf surface, as point loads reduce the load-bearing capacity.
For heavy books or decorations, it is recommended to distribute the weight evenly and to regularly check the shelves for damage where possible.
If you require a particularly high load capacity, for example for heavy collections, it would be advisable to install additional reinforcements or to use materials with higher strength.
I hope this answers your question adequately. If you would like more details regarding assembly or material properties, I am happy to help.
