ᐅ What is the best way to attach the back panel of the IKEA BRIMNES furniture?
Created on: 2 Aug 2024 09:37
keosan
keosan
2 Aug 2024 09:37
Hello everyone, I recently assembled an IKEA Brimnes furniture piece and now I’m wondering about the best way to secure the back panel. The back panel is relatively thin, usually made of particleboard or hardboard, and in the assembly video it’s often fixed only with small nails. My concern is that this type of attachment might not be stable enough over time or that the back panel could become loose.
Could you please share tips on proven methods to securely and permanently attach the back panel to the frame? Are there stronger alternatives to the small nails IKEA provides? Useful information on tools, fasteners, or even preparation of the back panel (for example, pre-drilling) would be appreciated.
I’m also interested in whether there is a specific order recommended for attaching the back panel on the Brimnes series to ensure everything holds well and nothing warps. Thanks in advance for your help!
RENMA
2 Aug 2024 12:04
The back panel of the IKEA BRIMNES is normally fixed with thin nails, which is sufficient for regular use but often not the most stable solution in the long term.
I recommend considering the following:
- Instead of nails, use small screws with spacers or washers to secure the back panel; this ensures a more durable connection.
- Pre-drilling is essential when using screws to prevent the material from splitting.
- Precise alignment of the back panel is crucial to avoid stress, so first loosely fix all fastening points and only tighten all screws fully at the end.
As an alternative, angle brackets can be used in the corners for additional stabilization, especially if the back panel will be subject to higher loads. This helps prevent frame warping.
Summary: small screws with pre-drilling plus angle brackets provide the most stable and long-lasting fixing.
Filippo
3 Aug 2024 10:22
To securely attach the back panel of the BRIMNES, it is important to consider the properties of the material. The back panel is usually made of MDF or hardboard with a thin groove designed to fit into the cabinet frame.
I would proceed step by step:
- First, align the back panel precisely to prevent any warping.
- Then remove any small nails if they have already been used, as they provide little holding strength.
- Pre-drill holes for screws with a thin drill bit (about 2-3mm (0.08-0.12 inches)) to avoid splitting the material.
- Instead of short screws, use chipboard screws with a diameter of 3.5mm (0.14 inches) and a length of about 15-20mm (0.6-0.8 inches), which are specifically designed for particleboard materials.
- At the corners and in the middle, attach additional metal angle brackets to reinforce the entire piece of furniture. These can be mounted either on the inside behind the back panel or on the outside of the frame.
A small but important recommendation: When pre-drilling and screwing the back panel, do not overtighten to prevent the board from warping or splitting.
One more question for you: Is your BRIMNES piece large or rather small (for example, a dresser versus a wardrobe)? This can be crucial for the need for additional reinforcements.
warrenka57
3 Aug 2024 15:59
Filippo schrieb:
One more question for you: Is your BRIMNES furniture piece large or rather small (e.g., dresser vs. wardrobe)? That can be crucial for the need of additional reinforcements.
That’s a great point—I had similar concerns when I assembled my large dresser. To be honest, the standard small nails initially held up well, but after a few months, the back panel started to wobble slightly. Of course, that’s unsettling because you don’t want to keep checking if everything is still secure.
I also screwed in small corner braces for extra support. When attaching the back panel, I first loosely fixed all the fastening points so I could still adjust the panel and avoid any stress. Finally, I tightened all the screws fully.
If you’re unsure, the extra effort is definitely worth it. You end up with a much more stable construction and less worry that the back panel will give way over time.
