I am planning to attach Ikea Pax mirrors to the doors of my Pax wardrobe and am looking for the best and safest method to do so without causing any damage to the doors or the mirrors. The doors are partly hollow and partly have reinforced backing, and I definitely want to avoid the mirrors falling off later or being attached in an unsightly way.
Does anyone have experience with the best way to secure the mirrors? Which materials or tools would you recommend, and how can I avoid potential issues such as damage or instability? I would appreciate a detailed discussion, as durability is very important to me. Thanks in advance for your tips!
Hello Leusnau,
When attaching Ikea Pax mirrors to doors, there are a few proven methods I can recommend based on personal experience. It is important not to use heavy screws directly into the doors themselves, as they are often hollow or have a thin support panel.
- Use mounting clips or mirror holders specifically designed for glass, which Ikea offers separately or can be found at specialty stores.
- Adhesive pads or double-sided mounting tapes with strong adhesion, such as 3M VHB, are a good alternative if the doors have a smooth back surface.
- If you choose to use screws, only do so through the door’s reinforcing strips—make sure to check carefully in advance where the material is thick enough.
- Before installation, it is advisable to clean the door and the area thoroughly so that no dust or grease residues affect the adhesion.
A combination of clips and additional adhesive tape increases stability and reduces the risk of damage or slipping.
Feel free to ask if you have any questions about the exact procedure.
JAPLO schrieb:
A combination of clips and additional adhesive tape increases stability and reduces the risk of damage or slipping. I can confirm that—I installed my mirrors the same way. The clips bear the load, while the tape ensures firm contact and prevents annoying rattling. It’s also important to install everything perfectly straight; otherwise, your mirror will hang crooked, which not only looks bad but also puts unnecessary strain on the mounting.
A little tip from experience: really take your time when marking and applying the tape. Sometimes the doors aren’t perfectly flat, so a bit of patience pays off. And yes, I’ve definitely sworn a bit afterward from placing a clip incorrectly—so having an extra pair of hands is invaluable. 😄
Other than that, it’s actually a pretty straightforward task that becomes very durable with the right materials.
Hello Leusnau,
I would like to add a few additional notes that are often overlooked:
- Carefully check beforehand whether the door material is really suitable for screws. With thin particle boards, the holding strength can be very poor, and the door might warp.
- If you decide to use screws, use additional anchors or special panel anchors to prevent the screws from pulling out.
- Mirrors are generally very sensitive to point loads. Therefore, mounting them with straight adhesive pads that distribute the load is advantageous.
- Another option is to use so-called mounting rails or shadow gap strips, which are attached at the top and bottom of the door. These hold the mirror securely and also allow easy removal later on.
In general, I would always recommend reading the original Ikea assembly instructions carefully. Often, the proposed fastening methods are better suited than you might think.
If you want, I can also provide you with the dimensions of the clips Ikea uses, so you can find suitable alternatives at your local hardware store.
