ᐅ What can you do if BILLY doors no longer stay closed?
Created on: 16 Sep 2022 08:37
Dokim54
Dokim54
16 Sep 2022 08:37
Hello everyone, I have the following problem with my BILLY shelves from IKEA: The doors no longer stay closed properly. As soon as you close the door, it doesn’t latch onto the frame or the adjacent furniture piece and opens by itself after a short time. It seems like the hinges or the magnetic catch might not be working correctly, or maybe the doors have warped.
I have already checked if the screws on the hinges are loose, but everything is tight. As far as I can tell, the doors are not warped.
Are there any tips or specific adjustments for BILLY doors that could help them close reliably and stay closed? I want to avoid completely removing the doors or having to buy replacement parts if there are simple adjustments available.
Thanks in advance for your advice and tips!
baAlejandr
16 Sep 2022 09:09
Hello, your issue with the BILLY doors is actually a well-known topic.
A common cause is indeed an incorrect adjustment of the hinges. The BILLY doors have two locking points that can be slightly adjusted: firstly, the distance from the door edge to the front of the furniture, and secondly, the height, allowing the door to be corrected slightly upwards or downwards.
I would recommend first loosening the hinges slightly with a screwdriver, positioning the door correctly, and then tightening the screws again. It is important to align the doors slightly with the magnetic catch, which usually ensures reliable closing.
If this does not help, the magnets can be replaced or small plastic or felt pads can be added to improve the hold.
In addition, it is also worth checking the hinge set (steel or plastic version). Especially if the doors are somewhat older, signs of wear may become noticeable.
barda6
16 Sep 2022 10:46
Can you check if the hinges are fully closed? Sometimes they are not flush.
Also, it often helps to realign the doors by adjusting the height and lateral settings on the hinges.
Often, it is also a plastic or felt stopper that is missing or has slipped out of place.
PAREL
17 Sep 2022 07:22
Hello everyone, I would like to offer a brief mini-tutorial on how to proceed with BILLY doors when they no longer close properly:
1. Check the hinges: BILLY cabinets typically use those standard cup hinges that can be adjusted in three directions. With a screwdriver, you can:
- move the door up or down vertically
- move the door sideways closer to or away from the cabinet carcass
- adjust the door depth (to set the correct closing pressure)
2. Adjust correctly: The door often opens if the closing pressure is not right or if it doesn’t pull sufficiently toward the cabinet. Finding the correct combination of adjustments is crucial here.
3. Evaluate the magnetic catch: Often, the small magnetic plates inside the cabinet are loose or worn out. If they are too weak, the door and cabinet will no longer hold securely together.
4. Add rubber or felt bumpers: If shifting weight or uneven door tension causes the door to open, you can usually attach small felt or rubber bumpers in strategic places (inside corners of the doors or cabinet) to create friction or extra hold.
5. Check for warping: Doors made of particleboard can warp slightly. Use a spirit level or straight edge to check if the door is hanging straight.
For illustration:
baAlejandr schrieb:
The BILLY doors have two locking points that can be slightly adjusted: one is the distance from the door edge to the furniture front, and the other is the height, which allows the door to be corrected slightly up or down.
That’s exactly right. In practice, I recommend proceeding step by step and closing the door after each adjustment to observe how it hangs.
If nothing helps, replacing the hinges or magnets might be the solution. IKEA usually sells these spare parts separately.
Good luck with the adjustments! 🙂
