katara133711 Apr 2019 13:45A question that has been on my mind lately, and one I haven’t been able to clarify yet since I don’t have an electrician, is the following: What does a “standard” electrical installation (not KNX or similar systems) look like during the shell construction phase when the cables are routed inside empty conduit on the rough subfloor? Let’s assume that in room X there are 6 electrical outlets, 1 light fixture with a switch, and 1 switch for an electric roller shutter. Does a single cable run from the distribution panel into room X and then get distributed throughout the room via flush-mounted boxes? Or do the cables run individually from each load back to the distribution board? So, in this example, would there be 2 cables for the two switches and 1 cable for the six outlets wired in series? Is this approach repeated from room to room, or are separate cables grouped together at some point?
katara133711 Apr 2019 14:01And are these cables then brought together in a flush-mounted box and run to the distribution cabinet in the utility room? Or are the cables laid directly to the utility room without a flush-mounted box?
e. By flush-mounted box, I mean a junction box.
katara133711 Apr 2019 14:24Okay, I understand that you connect or daisy-chain the outlets, but I have one last question. If you daisy-chain the outlets from two rooms and connect them to a single circuit breaker, and I want to turn off the breaker in room 1 to work on an outlet there, does that automatically cut off power to room 2 as well because everything is on the same breaker?
