Watcher7818 Feb 2016 09:52Hello,
we are getting a basement made of waterproof concrete (WU concrete) and I would like to know how others handle the electrical installation with switches and sockets in such cases. With WU concrete, only surface-mounted installation is possible. For the utility basement rooms, that is fine for us, but we will also have two living rooms, and we cannot install everything on the masonry interior walls.
Therefore, my question is whether it is possible or advisable to build a pre-installation wall to solve this issue. I was thinking of a drywall (gypsum board) partition.
Surely I am not the only one with this problem, right? How have you solved it?
Doc.Schnaggls18 Feb 2016 10:44Hello,
I don’t quite understand the problem.
What is your basic basement wall construction?
We have a basement made of waterproof concrete with double-shell precast walls, which were assembled on site and then filled with concrete.
All our sockets and switches in the entire basement are installed flush, that is, within the concrete wall itself, without exception.
For this, it was necessary to lay the conduit pipes or cables between the assembly and the concrete pouring of the walls.
Regards,
Dirk
Regards,
Dirk
Watcher7818 Feb 2016 10:59Hello Dirk,
thank you for your feedback. I didn’t know it was possible to install something in between. Our information was that only surface-mounted installations are possible in the basement. I will have to check on that again.
nordanney18 Feb 2016 11:36Question: Are all interior walls made of concrete? If not, can the majority of the wiring, switches, and sockets be installed there in the usual way? Otherwise, see Doc.Schnaggls.
Doc.Schnaggls18 Feb 2016 12:43@tomtom79: Not necessarily. Our basement is insulated from the outside. So, the walls in the living areas are just typical plastered and wallpapered concrete walls.
