ᐅ Mixed wall coverings inside the house, such as paintable fleece and fine plaster finish.
Created on: 24 May 2018 11:28
world-e
world-e
24 May 2018 11:28
who among you has different wall coverings in your house and finds it positive or negative? What are your opinions on this? Should wall coverings throughout the house be uniform, or is the variation what makes it interesting?
We are still undecided whether to use painting fleece or fine plaster on the walls. Or maybe a combination of both. For example, having the ceilings done with fine plaster (by a plasterer) and then applying painting fleece to the walls as a DIY project. Or perhaps doing the hallway ceiling with fine plaster due to its limited accessibility, and using painting fleece in the other rooms. Or would it be better to have everything done with fine plaster (or professionally applied)? On the ground floor, there is a solid wood ceiling, so it’s something completely different there. I imagine applying painting fleece to the ceiling would be quite tricky.
Thank you very much
