ᐅ Enhancing a Kallax Bench with a Wooden Top – What to Consider?
Created on: 2 Jul 2024 08:43
BaunathaliB
Baunathali2 Jul 2024 08:43Hello everyone,
I am planning to enhance my Ikea Kallax shelving units with a custom-made wooden top to create a comfortable bench. I want to ensure that the result is stable, durable, and visually appealing.
My specific question is: What should I consider when purchasing and installing the wooden top to make sure it fits the Kallax shelving unit perfectly? I am particularly interested in material selection, attachment methods, and possible reinforcements to ensure it can support weight reliably.
Additionally, I would like to know if there are any recommended surface treatments that can improve seating comfort and protect the wooden top from wear—perhaps water-resistant varnishes or oils?
Thanks in advance for your tips and experiences!
Hello Baunathali,
I find your project really exciting! Here is a structured overview of what you should consider:
1. Material choice: I recommend solid wood or laminated wood panels such as beech or oak. These woods are durable, relatively resistant, and have an elegant appearance. I would avoid particleboard or MDF panels, as they tend to absorb moisture quickly and swell.
2. Panel thickness: At least 18 mm (0.7 inches), preferably 22 mm (0.9 inches), to ensure sufficient stability and minimize warping.
3. Fastening: The best method is to screw from underneath into the shelf or use flat metal brackets that are hardly visible. Make sure not to drill too close to the edge to avoid splintering.
4. Reinforcement: If you’re unsure, you can attach strips to the underside of the panel to prevent it from bending.
5. Surface treatment: Oil is great because it looks natural, improves comfort when sitting, and can be reapplied if needed. Alternatively, water-resistant varnishes (acrylic or polyurethane coatings) offer very good protection but are slightly less breathable.
A small tip at the end: Before purchasing, check the exact dimensions of your Kallax shelving unit, as sizes can vary slightly—better to allow some margin and trim or sand it yourself if needed.
I hope this helps!
I hope this helps!
Nabla64 schrieb:
Panel thickness: At least 18 mm (0.7 inches), preferably 22 mm (0.9 inches), to ensure sufficient stability and minimize warping.Interesting point, but is thickness really the only decisive factor? The way the load is distributed and how the panel is fixed to the shelf also matter.
I have seen thinner panels remain very sturdy for years with a clever substructure – maybe it’s better to think about overall stability rather than just increasing thickness.
I also wonder if the finish—whether paint or oil—affects the screw holding power? For me, it would be important to know if the fastenings and surface treatment influence each other. For example, a water-repellent coating can harden the wood somewhat, which reduces damage when screwing in, but what about the long-term durability?
I’m also interested if anyone has experience with alternative materials that might be more sustainable. For example, plywood panels are often stable and less prone to warping, but their interior layers don’t look as nice—could that be an issue for a visible bench?
Hey Baunathali and all other wood enthusiasts!
Your ideas here are fantastic! 🙂 By the way, I made my Kallax bench using a self-oiled oak board, and I’m really happy with it!
Just a tip: Make sure to pay special attention to the edges when oiling or varnishing – be thorough, especially on the cut edges, because otherwise the wood will absorb moisture, which can quickly spoil the fun.
I’d also suggest considering bamboo. It’s extremely durable and looks great. It’s a bit more expensive, but it’s a real eye-catcher and environmentally friendly.
One more thing: If you want it to be comfortable, a thin seat cushion with a non-slip backing would be perfect, so you get the best of both wood aesthetics and comfort!
Looking forward to more updates from you all! Good luck with your building projects :-)
