ᐅ Telecommunication cable J-Y(ST)Y 2x2x0.8 installed in concrete
Created on: 4 Jun 2019 11:52
julianpe
julianpe
4 Jun 2019 11:52
I couldn’t find an answer to my question.
I want to install a telecommunication cable J-Y(ST)Y 2x2x0.8 on the ribbed concrete ceiling.
The cable will be used for the window contact switches.
Does the cable necessarily need to be placed in a conduit when the concrete is poured, or can I lay it like this?
Thank you very much
guckuck2
4 Jun 2019 12:13
I believe the question becomes irrelevant when you compare the risk (failure of window contact) with the effort (a few euros), right?
Keep in mind, you’re dealing with construction workers. With iron, angle grinders, boots, concrete pumps, and shovels. Protect your cables as much as possible.
danixf
4 Jun 2019 18:06
guckuck2 schrieb:
Keep in mind, there are structural workers on site. With rebar, angle grinders, boots, concrete pump, and shovels. Protect your cables as much as possible
Funny... They just cut the empty conduits for me.
But no, I wouldn’t run this cable through the ceiling.
I would either use J-2Y(St)Y or A-2YF(L)2Y.
But why do you want to install the cables in the ceiling already?
julianpe
4 Jun 2019 20:11
danixf schrieb:
Funny... In my case, they simply cut the empty conduits.
But no, I wouldn’t run that cable in the ceiling.
The electrician said we should put as much as possible in the ceiling now, so that later we don’t have to run cable across the rooms. I have now installed it in empty conduits.
