ᐅ Giving Away Kallax Shelving with Bulk Waste – An Environmental Issue?
Created on: 22 Nov 2020 18:42
Baran4
Baran4
22 Nov 2020 18:42
I am currently considering whether it poses an environmental issue to dispose of a Kallax shelving unit through bulky waste collection. My thought is that the Kallax system is made from particleboard, often coated and combined with various materials – for example, ABS edging or lacquered surfaces.
From an environmental perspective, I am wondering to what extent disposal through bulky waste collection is actually effective for the recovery or recycling of this type of furniture. For instance: Are the materials properly separated and recycled there? Are there harmful substances that could be released during landfill or incineration?
Additionally, would it be more sensible to disassemble the furniture piece by piece and dispose of the individual components separately? Or are there already established procedures that apply when disposing of such items via bulky waste collection?
I would appreciate it if someone with experience or relevant expertise could explain the bulky waste disposal process and its environmental implications in this context in detail.
Thank you in advance!
lalutau
22 Nov 2020 19:03
Baran4 schrieb:
Are there harmful substances that can be released during landfill disposal or incineration?
Kallax furniture is mostly made from medium-density fiberboard (MDF) or particleboard, often coated with melamine resin. These materials contain adhesives with formaldehyde, which can release harmful substances if burned improperly.
In most municipalities, disposal via bulky waste collection means the furniture is either sent to a sorting facility for recycling or used for thermal recovery. However, sorting is not perfect, so many composite materials are not separated efficiently.
Separating and dismantling the furniture into wood and plastic parts generally improves recycling rates, but this is not always practical for private individuals.
Environmental harm mainly occurs when furniture ends up in landfills, potentially releasing pollutants over time, or when incineration leads to uncontrolled emissions.
My advice: If possible, dispose of furniture through specialized recycling centers or take-back programs that ensure proper handling of wood-based materials.
kibutar
23 Nov 2020 07:28
Baran4 schrieb:
Are the materials sufficiently separated and recycled there?
In general, the handling of bulky waste varies significantly by region, but often an initial rough sorting takes place – in this process, the Kallax furniture is usually considered as a whole unit. Since it is made of particleboard, shredding releases formaldehyde and other volatile organic compounds, which can be problematic during incineration or storage.
The design type of Kallax is also not intended for reuse: there are no modular connections that allow easy disassembly. Therefore, this furniture mostly ends up in thermal recycling (incineration).
A problem lies in the coating: melamine resins or ABS edges are plastics that can emit harmful substances when burned, especially if the filtration systems in the waste-to-energy plants are not adequate.
Furthermore, bulky waste disposal has a major drawback – waste volumes fluctuate significantly, which affects sorting quality and can reduce recycling rates.
My suggestion: due to its composition, Kallax should be taken to local recycling centers that enable targeted material separation, or sold via secondhand platforms. If environmental protection is important to you, sending it straight to bulky waste is not the best option.
Have you looked into how your local disposal facility operates? Knowing this would be important to realistically assess the environmental impact.
Deoren
23 Nov 2020 08:59
In short: Disposing of Kallax as bulky waste is not ideal. It's better to disassemble it and dispose of the wood and plastic components separately.
Pressboard containing formaldehyde should not be taken to the landfill. Recycling centers offer better disposal options.
JAFUHAU
24 Nov 2020 11:11
kibutar schrieb:
My suggestion: For Kallax, it’s better to rely on local recycling centers that allow for targeted material separation, or to use secondhand platforms.
I fully support this. Especially considering how long such a piece of furniture has been in use, it can feel good to pass it on to someone who appreciates it instead of it ending up in bulky waste.
However, I also understand that this isn’t an easy option for many, especially when space needs to be cleared quickly. I’ve personally experienced this—furniture I left out for bulky waste could definitely have been reused.
So maybe a suggestion would be to think beyond just environmental concerns: Could the Kallax be given away, sold, or even donated for upcycling projects in parts?
Sometimes a small step can make more of a difference than simply disposing of it, which should ideally be the last resort anyway.
