ᐅ Sealing the foundation slab before the roof is installed
Created on: 20 Oct 2017 20:57
winnetou78
When is it common to waterproof the concrete slab from the top, I mean at what stage? The construction company plans to do this before the roof is installed. Is that a good approach? Won't rainwater then accumulate inside the house?
Regards,
Daniel
winnetou78
20 Oct 2017 22:22
The question is whether it will dry if the weather becomes more humid now.
No, he doesn’t want to place the partition walls directly on the raw concrete slab.
I really understood it this way:
Finish the exterior walls, complete the waterproofing on the slab, and then build the partition walls on top of that.
And I have doubts whether that is okay.
Is there some special material under the walls and a normal bitumen membrane elsewhere?
Yilmaz20 Oct 2017 22:42
Once the roof is in place and there is ventilation, it will dry out.
No waterproofing membrane (roofing felt) should be installed under the masonry.
winnetou78
20 Oct 2017 22:44
So, is it technically incorrect to apply the waterproofing directly to the walls?
RobsonMKK20 Oct 2017 22:46
Yes, but not on bitumen membrane. How else should it be sealed tightly?
winnetou78
20 Oct 2017 22:50
I’m talking about the fully sealed foundation slab and building the walls on top.
It’s clear that a waterproofing layer needs to be applied underneath during construction.
However, these seem to be different materials.
winnetou78
20 Oct 2017 22:54
Could it also be that he wants to use a sanded bitumen membrane for the entire concrete slab? Would that be technically acceptable?
